Engine speed
   / Engine speed #1
ducksjunk
Burks Falls, Ontario
yanmar 195D (for sale)
I see a lot of talk about speeds of 2700 RPM in the forum. This seems to me an excessive speed for my 2 cyl. 195D.
Also the limit screw (high speed) has a flattened end with a hole i it like there should be a spring or something attached to it. Can anyone enlighten this old fool?? /forums/images/graemlins/tongue.gif
   / Engine speed #2
"I see a lot of talk about speeds of 2700 RPM in the forum. This seems to me an excessive speed for my 2 cyl. 195D."
2700 RPM is excessive operating speed, that is usually max RPM, (2700-2800), on a Yanmar. 2200 is a more normal operating speed. Never knew they even had a high speed limit screw.
   / Engine speed
Maybe it's not. It's on the linkage at the trottle body.
Mine tops out at about 2000 RPM
   / Engine speed #4
ducksjunk,
I believe the flat ended screw (opposite your throttle stop) originally had aircraft style wire with a lead crimp to indicate the factory throttle setting.
Is there any indication on your tachometer showing normal or maximum RPM? I don't recall any two cylinder Yanmar running 2700, but I could be wrong.
   / Engine speed #5
I thought the YM135 and YM155 both ran at 2700 rpm. My YM1110D (2 cyl) parts manual indicates that the engine (2T72) is rated at 11 ps at 2700 rpm.
   / Engine speed #6
Yep your right.....funny thing too as I have a 1300d. Clear case of look before I leap...thanks for the correct information.
Mark
   / Engine speed #7
Quoted from the YM195/YM240 operation manual:
Slow idle 800 rpm
fast idle and max road speed YM195 2550 rpm
fast idle and max road speed YM240 2600 rpm
Full throttle full load 2400 rpm
normal working speed 1800-2400 rpm
and PTO 540 @ 2200.
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
JOHN DEERE 7210R LOT IDENTIFIER 257 (A53084)
JOHN DEERE 7210R...
(APPROX 100) UNUSED LANDHERO T-TOP BOLLARD (A51248)
(APPROX 100)...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
1269 (A50490)
1269 (A50490)
