engine specs
   / engine specs #1
moburn0806
Evergreen CO
New Holland 2005
does anyone know what the compression ratio should be for a 2005 New Holland TC35A diesel? I'm looking at buying; it has 1600 hours and I want the compression checked. Thanks, Moburn
   / engine specs #2
It's would be pretty hard to wear out an engine in 1600 hrs unless you ran it witout an airfilter in dusty condions.
Most of these machines have a compression ratio of~ 18. Compression pressure ratio, Pcompression/pambient, is about 36.5. So if the ambient pressure is 14.7 psia, compression pressure should be around 537 psig +/_ .
The owners manual should have a spec level in it or a NH dealer might be able to tell you correct levels. My gut feel is that it shouldn't be any less than about 450 psig @ an ambient pressure of 14.7 psia. Remember, the measured compression pressure will be a function of the ambient pressure so if the test is conducted at high altitudes the measured compression pressure will be less.
   / engine specs #4
Your engine is a Shibaura N843L with a compression ratio of 22.5:1 and a compression pressure at 200 rpm of 427 psi plus or minus 50 psi.
   / engine specs #5
I didn't realize that the compression ratio would be that high. The min allowable pressure is 355 psi per the Shibaura manual is.
thanks for the info.
2001 J ODell 16ft Enclosed T/A Trailer (A51694)
2001 J ODell 16ft...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
1987 FRUEHAUF 8,000 GAL TRAILER (A53843)
1987 FRUEHAUF...
