engine specs and info on the 57 john deere 420
   / engine specs and info on the 57 john deere 420 #1
nickk
port hope ontario
john deere 40/420
hi i'm new to the forum. i need the engine spec and cylinder bore tolerances for the jd 420. the tractor has a knock and i've pin pointed the problem to the cylinder pin bushing and connecting rod bearing . i'm hoping i don't also have to bore out the cylinder if i dont have to.
Thanks,
Nick k
   / engine specs and info on the 57 john deere 420 #2
the JD web site has the parts book for free.
The nice folks at 1-800-522-7448 have the real JD service and operators manuals on CD or hard copy. In IT manual is best rolled up and used to swat flies.
make sure the oil passage to the valve train isn't blocked when re-assembling. This would be the time to install a new bushing in the distributor and ensure the advance weights work freely. Over advanced timing will pound wrist pins, rings, rods and rod bearings to bits.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
