Engine RPM vs PTO rpm
   / Engine RPM vs PTO rpm #1
Jjpbe
Yanmar 1510D / Kubota L245/ Toro 223D
Good day,
I would like to know how much engine RPM I need to set on my YM1510D when working with 540 RPM on the PTO? ( don稚 have the manual yet) Can someone tell me?
Thank you very much in advance.
Jjp
   / Engine RPM vs PTO rpm #2
It's not critical, but on smaller machines it's usually just about at MAX engine RPM. I guess a little is left for overhead.
   / Engine RPM vs PTO rpm #3
Most are marked on the tach.
On my Kioti I have 'E 540' just under 2k rpm and '540' at about 2600.
I'm assuming that's the same 540 rpm at the output shaft to the implement...but have no real idea ohter than of course, lower revs uses less fuel.
Thank you all for the reply
Jjp
   / Engine RPM vs PTO rpm #6
Little tractors are known for resonance and vibration. Sometimes it's more important to pick a speed that runs the smoothest, in that neigborhood of course.
   / Engine RPM vs PTO rpm #7
For the similar US model YM186D: the original showroom brochure says PTO rpm 540 @ 2400 engine rpm.
And credit to the original posters. My notes say:
International284's Photobucket_files ref from TBN, spring 2011.
Originally from rScotty who sent them to I-284.
Thanks, International and rScotty!
   / Engine RPM vs PTO rpm #8
Good day,
Jjp
On the 4010 (like a JD 2019E in today's nomenclature), it was about 3,100-3,200 rpm to get 540 rpm on the PTO, and I ran it at that speed because I needed the full 18.5 hp from the engine.
On both the 1025R and 2025R with near 25 hp, I do not need the full hp of those engines. Therefore, I ran/run them at about 2,500 rpm vs. about 3,100 for 540 PTO.
Ralph
   / Engine RPM vs PTO rpm #9
On my M6040, the owners manual says - 2160 engine rpm = 540 pto rpm. When I engage the pto, the dash reads out the pto rpm. I often run the engine at 1800 to 1900 rpm. I chip only green pine trees - 6" diameter at the base, or less. Only slightly harder than month old Twinkies.
   / Engine RPM vs PTO rpm #10
https://redirect.viglink.com/?forma...fermer.ru/files/v2/forum/183...191ym1510d.pdf
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
SWINGER 2K LOADER (A52472)
SWINGER 2K LOADER...
2007 KENWORTH W900L DAY CAB (A52472)
2007 KENWORTH...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
