Engine RPM for Backhoe
   / Engine RPM for Backhoe #1
Glrret
Somerset County, Maine
Mahindra 2555 Shuttle
I have a 2555 Shuttle and a 75B Backhoe, I've read the operator manuals and I'm not able find the recommended RPM to use.
   / Engine RPM for Backhoe #2
I think backhoes are more operator preference as far as RPM.
Run whatever RPM the backhoe speed and control is where you like it.
   / Engine RPM for Backhoe #3
I run my 3pt mounted backhoe with tractor throttle at 1800-2000, unless I am doing something that requires more power. It is easier for me to control it.
   / Engine RPM for Backhoe #4
I think you may find in your operators manual to not run any operations below 1500 rpm, which is right about where my backhoe is plenty fast and powerful enough.
   / Engine RPM for Backhoe #5
My 3-point backhoe (photo in sig) was specified for this tractor but even so, I've read that any 3-point hoe beats up the tractor more than a frame-mount version.
1350 engine rpm just sounds right for full backhoe power with smooth motions. My most common task is digging out stumps where I don't want to snap off lateral roots before I dig outward along them to free them so faster isn't necessarily better. I need to feel when the bucket encounters resistance.
If I know I can work fast and not run into obstacles then up to 1800 rpm but that's not common - and that requires more concentration to feather the end of the boom swing. Previous owner of this hoe said he tried using it a few hours and 'couldn't get the hang of it' so he never used it again. Where the roller chain for swing attaches to the chassis I found a fresh weld. I think he broke it the first time he used it. Several years now for me and no problems.
I occasionally shift the pto to its '1000 rpm output' gear, then run the engine around 1050 for very light work such as using the hoe to rip out blackberry jungle. This is essentially idling the engine, not working it. Actual rpm out the pto is still below 540 and the hoe has a decal specifying 'not over 650 rpm input' or something like that - faster than I would ever use.
Just choose what feels right. You don't need the engine's full rated pto rpm.
   / Engine RPM for Backhoe #6
Every tractor/hoe is going to run best at different speeds, depending on pump and hyd cylinder sizes. You need to run it at whatever feels right for you. I run mine between 1500-1800rpms.
Without knowing any better I've been running the engine @1500 rpm it seems to operate smoothly at that setting. I found it odd that the manual didn't provide any guidance.
   / Engine RPM for Backhoe #8
The tractor will tell you when it needs more....
   / Engine RPM for Backhoe #9
Throttle UP!! You have the model tractor that Mahindra is having issues with. EGR,MIL light. poor heat. High RPM at this point is there only solution.:thumbsup:
Seems like a lot of unnecessary stress on the engine and hydraulics to over come a problem in design. I hope Mahindra finds a fix soon..
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2015 Ford Econoline Shuttle Bus (A50323)
2015 Ford...
7046 (A50322)
7046 (A50322)
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
