Engine rebuild TO35
   / Engine rebuild TO35 #2
Probably a bit late of a reply. I used the video and thought it was very good. It was easy to follow and for the most part correct. I chickened out on timing the fuel injection system and got a shop to help. I couldn't follow their instructions before it was done , but can now after I have seen it done.
I overhauled my 23c a little over a year ago and am tickled pink with the results. Cam Bearings and pre-combustion chambers are about the only items that are not readily available. I ended up having to get a new (used) block as mine was cracked around the center main bearing support. I understand that is fairly common for them to crack, and blocks are getting a bit rare. Some can be welded by skilled enough person.
The whole project took about 6 months in rounding up parts and finding time. More time was spent in cleaning and painting than fixing.
2021 JOHN DEERE 6130R LOT NUMBER 46 (A53084)
2021 JOHN DEERE...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
199049 (A51243)
199049 (A51243)
