I was back blading my driveway going up hill on my JD 110 when I heard a slight pinging in motor I believe with the RPMs dropping slightly and a bit of black smoke coming from the exhaust. I was doing short passes and each time I got to the steep part it got a little worse and after about 4 times it stalled on me. I tried cranking it over and it almost started then stopped. Now it won't even turn over....
It is as if there is resistance somewhere stalling the motor. I think it is either the motor itself or could one of the hydraulic pumps be failing and cause enough resistance to stall the motor?
I am going to head out and disconnect the main implement pump and see if that changes anything. Does anyone know if I can take the auxiliary/steering pump out of the system to rule that out too?
I don't really know where to go from there with out splitting the tractor to check the transmission... very big job.
Would the oil pan drain screw indicate if there was an engine failure? How do you check if it's an engine failure if you can not turn the engine over?
Is there anything else connected that could stall the motor?
Any advice would be appreciated.
Kelly
Kelly
