Engine Overhaul
   / Engine Overhaul #1
Litdave
Hello Everbody,
First, let me say, I have been searching the web for tractor information and this site seems to be by far the best site on the web.
I just recently joined this board but I have been hanging around for the last month. I just bought 4 ac and I am getting ready to buy a tractor.
The question I have is: How much would it cost for me (parts and maching labor only) to rebuild a Ford/New Holland 1720. I have found a 1997 for $3500 but it has spun a crank bearing. The tractor is in good condition otherwise.
I have rebuilt quite a few automotive gasoline engines and rebuilding a diesel doesn't seem like it would be much different except for the injectors and injector pumps.
Any opinions would be very much appreciated not only on the cost of the overhaul but also the tractor's value and any problem areas I should be aware of.
Thanks, Dave
   / Engine Overhaul #2
I am by no means an auto mechanic, but I would have to wonder that if that tracor was worked hard enought to cause the engine to spin a bearing what else is getting weak. Someone esle that has had these tractor will chim in I hope.
   / Engine Overhaul #3
I don't know what the parts would cost. What parts you need kinda depends on what else happened when the bearing spun.
Did anything get bent and or cracked? You should be able to get prices from a dealer on replacement crank, rod, piston etc.. If the crank just needs turned and new bearings then great otherwise it will add up quick if tractors are anything like boat motors(Most likely much worse being a diesel).
How many hours does it have on it? Is it about due for a rebuild anyway?(Read as Mo money) What is one of these tractors worth(Running) with the hours that are on it.
I've built a number a gas street and race engines myself. Unless I could inspect the engine or talk to the qualified mech that examined it, I'd have to assume the worst.
I'd scope the engine if its' not apart.
   / Engine Overhaul #4
You need to know if the spun bearing is a rod or main. A rod is no big deal, if a main is spun you will need a block or some expensive machine work.
   / Engine Overhaul
Thanks, Guys
Here is what i know.
The tractor has been partially disasembled. The bearing that was spun was on the rod. One rod may be bad but the block is OK.
The pan had a lot metal in the bottom when it was pulled.
I don't know why the bearing spun, but I would suspect it was due to negligence/low oil.
The tractor is a 1997 and it has 1600 hours on it and it was used for golf course maintainace. I suspect the hardest thing this tractor done was mow grass. It has turf tires on it.
I have no reason to suspect that there are anyother problems with the tractor - but no guarantees.
Overall it is a pretty clean looking tractor with a live PTO, 4WD, and good rubber.
   / Engine Overhaul #6
The real question is why doesn't the present owner repair it if it isn't that badly damaged. A spun bearing isn't that big of a deal. Most times the journal can be turned an new bearings fitted. I would b inclined to check the cylinders for additional problems. It might be that you will have to go with over sized pistons, etc to properly repair this engine. I would suggest that you talk to a company that does diesel engine rebuilding and get a idea of cost from them. They will be familiar with what usually needs to be reconditioned on the engine and probably have worked on that model before. In rebuilding engines, it is always the learning curve that take its toll of time. I agree, it was probably poor maintenance that killed this tractor, but golf courses and cemeteries are known for this...
   / Engine Overhaul
Junkman (and others),
The story is getting complicated. The original owner had a bussiness taking care of golfcourses. He has gone bankrupt. The tractor is currently at a dealer where it is partially torn down.
The tractor is actually owned by a bank who will pay the dealer to "patch up the tractor" and then sell it for $6000. The problem is the bank only wants to "patch" the tractor with a welded and turned crank and new bearings.
I think the whole engine needs to be torn apart and all of the remaining metal particles flushed out and other parts inspected for damage. Otherwise I don't think the engine is going to last. The bank doesn't care wants it gets it's money and the dealer won't warranty the "patch job".
If I buy the tractor "as is" I can buy it $2500 cheaper. The question really boils down to can I rebuild the engine (or have it rebuilt) properly for $2500 dollars.
I think I can buy a short block for $3000.
I think I can rebuild it myself for about $2000 in parts including a new crank, boring the cylinder and oversize pistons. This does not include head work or injector work.
This is what I am inclined to do but I have never rebuilt a diesel engine, only gas engines.
I was wondering what you guys thought of someone rebuiding a diesel engine with no prior diesel experience and also is there any "gothas" that I should know about.
I would also replace the clutches while it is apart if they show any significant wear.
Thanks again, Dave
   / Engine Overhaul #8
Litdave:
I am going to stick my neck out a bit here. The rest of you guys please don't bite me as I don't know the mechanical abilities of the poster.
A diesel engine is the same as a gasoline engine (basically). Diesels are built heavier because the increase in compression puts an added strain on the components internally and externally. A gasoline engine has a carburetor or fuel injected and the mixture is ignited by a spark whereas a diesel engine is injected, but the mixture is ignited by compression pressure heating the mixture to ignition temperature.
Gas and diesel engines share the same type of parts internally so if you can rebuild a gasoline engine, you should be able to rebuild a diesel engine. With a couple of exceptions.
Keep your fingers out of the injection pump or should I say a screwdriver or wrench. Don't disassemble the injectors either.
If you want either of these items rebuilt or checked, take them to a dealer or better yet, to a diesel injection specialist.
I'd invest in a shop manual for the tractor and I don't mean the generic variety. I mean the factory authorized manual.
Proceed carefully and you should be all right.
   / Engine Overhaul
5030,
This is what I was hoping to hear.
--- Understood
--- This is what I thought.
--- This is also what I thought.
--- I allready understand that injectors are not something for the untrained to mess with and I would not attempt to do so. If I susspect anything wrong with the injectors/pump I would take it to somebody who knows what they are doing.
--- Good advice, I wouldn't attempt and engine rebuild without one.
--- Thanks, Dave
   / Engine Overhaul #10
depending on the engine there are other slight differences. The blok my be wet or dry sleved requireing setting and possible sealing of the sleves, not hard but different. I called by ford shop on this and they state that there is not a rebuild kit for this engine, all parts need to be bought individually, in fact when buying rod bearings they are sold by the half bearing /forums/images/graemlins/confused.gif so you need to buy two for each rod. He stated that there are about 4 serial number breaks for that model tractor and you should get the s/n of the tractor and see what break the engine is in. Gaskets can be bought as a set.
There are numerous pistons and ring varations used and you will need to make sure that the ones you get are proper.
The other statement he made is that the parts are "spendy" but if you buy the tractor right, who cares?
Dane
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
205113 (A52706)
205113 (A52706)
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
