Engine oil
   / Engine oil #1
Bob Felix
S470d
I pulled the engine oil drain plug and nothing came out. The dipstick shows more than enough oil in the engine, yet it won't drain. Any suggestions on how to get it to drain?
   / Engine oil #2
Poke something into the drain hole and see if there is a clog?
   / Engine oil #3
Did you really pull the drain plug, or a pan bolt?
   / Engine oil #4
If it's some kind of crud or blockage you may wish to pull the oil pan and clean it out.
   / Engine oil #5
As other have stated also remove dip stick.
   / Engine oil #6
   / Engine oil #7
Ya right. Is this tractor new to you? What’s the oil change history? Maybe you’ve turned the wrong bolt? If the oil wouldn’t flow then it wouldn’t lubricate either…. Or You’re pulling our legs
   / Engine oil #8
Apparently Mr Felix was here at 0905 today but neglected to update….🤷
   / Engine oil #9
I hope Mr Felix returns with something more about his mysterious oil drain problem.
This is why new members should be required to make at least 12 to 15 contributory posts to existing threads, before being permitted to start a thread, and 25 or more before being permitted to post For Sale in the classifieds.
There are other various forums out there with similar, if not even more stringent, rules. It works, costs nothing, and keeps a lot of pot-stirring thread starters off the forum.
   / Engine oil #10
Might be a good idea. True storey, I had a buddy call me asking why his oil was way overfilled after he changed the oil in his truck many years ago. Turned out he drained the front axle, changed the oil filter and then added the appropriate amount of engine oil on top of the old oil…oopsy
2011 DOOSAN G25 GENERATOR (A53843)
2011 DOOSAN G25...
100 FUEL TANK (A53843)
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
BRAND NEW LENOVO LAPTOP (A53843)
BRAND NEW LENOVO...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A53473)
Adams Load Out...
