Oil & Fuel Engine oil seal replacement
   / Engine oil seal replacement #1
CanuckGT
Bronze Member
Dino Valley,Ab Canada
Kioti CK30 HST
Hi all, I have a leaking front engine crank seal that I plan on changing, searching for any info on this task but I come up with nothing.
I am wondering if I have to remove the front gear case to do the job? Should I replace just the seal or the oil slinger,spacer,etc?
How difficult is the job?
Thanks.
   / Engine oil seal replacement #2
It does appear that the gear case must come off. I would pull the crank pulley off and see what you can see. You're going to need a few other o-rings for the oil filter port passageways and such, that also run through the case. Once you get the case off, have a look, there may or may not be more items to change out. The slinger ring and bushings are super cheap, certainly wouldn't hurt to have them on hand when doing the job.
have a look here Parts Finder Michigan Iron & Equipment Morrice, MI (855) 265-459
and here Parts Finder Michigan Iron & Equipment Morrice, MI (855) 265-459
CFG Industrial MX15RX (A50121)
CFG Industrial...
2009 Chrysler Sebring LX Convertible (A50324)
2009 Chrysler...
Bush Hog 2615 Batwing Mower (A50514)
Bush Hog 2615...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2014 Ford Escape SUV (A50324)
2014 Ford Escape...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
