Engine oil For DK series Tractors.......Winter is just around the corner
   / Engine oil For DK series Tractors.......Winter is just around the corner #1
grm61
Platinum Member
Eastern Washington
2013 Kioti DK45SE HST Cab
So I'm coming up on the 50 hour service, What are you guys running for oil? And what viscosity?
Winters will be here before we know it, I like the idea of a synthetic because it flows much better at cold temps, and I don't have a block heater.
Has anyone read if 50 hours is enough break in to switch to a synthetic? I also read that kioti runs these motors on a dyno for a hour before they ever go into a tractor.
My motor sounds happy, and has not used a drop of oil, the oil still looks clean, so I'm thinking the rings are seated fine.
Thoughts?
   / Engine oil For DK series Tractors.......Winter is just around the corner #2
I run Rotella T-6 synthetic 5w-40 in my DK 35.
Switched over at the 50 hour service and its the only oil I have run in the tractor since.
   / Engine oil For DK series Tractors.......Winter is just around the corner #3
I ran T6 5w40 as well, until the 200hr service, now I have 15w40 in as I never had to start the tractor below -10C anyways. My oil definetly gets black though. Also in theory, your next oil change is at 100 hrs, so going to synthetic is kind of a waste. I ended up putting the 50hr 5w40 into my old Neon...
   / Engine oil For DK series Tractors.......Winter is just around the corner #4
I do the same as DK35vince. Actually, I went that way from a prior posting of his being that our Winters are the same. Coldest start was -3F' with no problem. I just needed to cycle the glow plugs twice. I run the 5w-40 year round and started at the 50 hour service. Coming up on my 500 hour change soon. I think Vince has twice my hours. You could definately use another brand, as I'm sure other members do, but the 5w-40 synthetic has worked great for me.
   / Engine oil For DK series Tractors.......Winter is just around the corner #5
I would need to check the owners manual.
But I thought the first change was 50 hours. Then every 100 hours after that.
If the OP changes oil at 50 hours, he shouldn't be do for the next change till 150 hours
   / Engine oil For DK series Tractors.......Winter is just around the corner #6
Close Victor.
I'm actually at around 1780 hours.
   / Engine oil For DK series Tractors.......Winter is just around the corner #7
if you like syn.. and it's time for the change in oil.. you can go with the aforementioned 5w40
good temp range on it...
   / Engine oil For DK series Tractors.......Winter is just around the corner #8
I read it as change at 50, then change at 100. Then every 100... So that is what I did.. Getting close to the 200. I have been using Rotella 15W40, our winters are mild.
   / Engine oil For DK series Tractors.......Winter is just around the corner #9
The important thing is to use a API C-rated oil (C for compression ignition i.e. Diesel) with the right viscosity. Diesel engines produce lots of soot that gets in the oil so the oil must have the additives to keep the soot in suspension. Oils rates S only (for spark) may be wonderful in gas engines but are not suitable for use in Diesel engines. Also unlike gas engines, you cannot extend oil change intervals for Diesels, no matter how good the oil is (unless you have special soot filters like some large commercial Diesels). The main benefits of synthetics are easier cold-weather starting (even with 15W50) and the oil sticks to the metal longer. In fact, you usually need to wait some time after stopping the engine to get an accurate reading on the dip stick.
Personally, I use Mobile 1 or or Rotella T6 in all my engines, even the lawn mower (5w30 in the gas engines and 0w40 (M1), 5w40 (T6), or 15w50 (M1) in Diesels). The cost savings with a conventional oil just isn't very great and if the synthetic can improve engine life, why take the risk. My Kioti manual says 10w40 is OK for all temperature ranges.
   / Engine oil For DK series Tractors.......Winter is just around the corner #10
What do you all think about using Lucas additive? I used it in my old Yanmar tractor. Heck, I have used in everything for years. I am coming up on my 50 hour as well and was planning on using it. Any thoughts?
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
