Oil & Fuel Engine Oil for BX2350
   / Engine Oil for BX2350 #1
klrobert
Cullman, AL
Kubota BX2350
I am enjoying my new Kubota, although we haven't had any rain for quite some time, so not much mowing to be done. I am not there yet, but getting closer to the 50 hr service. I don't want to open a can of worms here, but would just like to know how many people use the Kubota brand motor oil. I am sure it is more expensive than other brands, but no more than I run one, probably one or two oil changes per year will be all that is required. If it is just a few dollars more for an oil change, wouldn't this be cheap insurance? I am not saying it is better, but if Kubota puts their name on it, I feel it is formulated for their engines. I may be totally wrong here, but at least it won't be the first time. :confused:
   / Engine Oil for BX2350 #2
I used Rotella in my BX2200 after the warranty period was over. Will probably do the same with the new tractor. That said, I did that because of the warranty only.. I preferred the Rotella. Cheaper at Sams Club....
   / Engine Oil for BX2350 #3
It is a good time to draw caution! Most diesel oils for tractors is more expensive to make then for trucks and cars! When you mow your lawn it's normally at or near full throttle same as the farm tractors out in the field not at 1/4 or 1/2 throttle like trucks and cars.
For a dollar or two a change it is cheaper to buy the better oil. We've seen plenty of engine failures and you can tell the difference!
   / Engine Oil for BX2350 #4
It does not have to be Kubota, just make sure its an off-road grade oil. Not whatever wal-mart special is on the end cap for $0.99/qt.
   / Engine Oil for BX2350 #5
I use the Rotella in mine as well as the five loaders and three bulldozers and the backhoes and the big trucks and.......... It is good stuff...
   / Engine Oil for BX2350 #6
I use Amsoil Diesel oils and no worries...
   / Engine Oil for BX2350 #7
It is not a dollar to two more, way more. Kubotas oil is someones oil with their name one it. The diesel engine in the trucks take way more abuse then these tractors, period. They are supposed to last 500,000 miles between rebuilds. They have extreme loads put on them, idle for very long periods of time (without racking up miles), and you would be supprised how much the diesels trucks are beat on. Most of these guys in the fleet straight jobs have the pedal to the floor constantly when the light turns green and they are governed @ 65mph (I know, i was one of them). Not to mention the guys hauling some serious weight up and down the mountians.....
heres a good oil write up. Sure there are more out there... If you dont want to read the whole thing scroll down to the the commercial diesel.
All About Motor Oil
Theres also a section how these fleet companies run periodic test on the oil to ensure the oil is performing up to the task on the high demands of these diesels...
After paying $45 for 1 male and female quick coupler from the dealer, I am done purchaseing from there unless i have too. They had a diesel can there for $27... Thats NUTS!!!
Everyone has their opinions and what they prefer, and if using the kubota oil is what you like than thats great. Dont get me wrong, I am not saying dont use kubota oil! What ever helps you sleep better at night.
Sorry for going on a bit, but i dont buy over prices products just because of the name, especially if there are better opions!
   / Engine Oil for BX2350 #8
FWIW I second your post.
Same experience here.
   / Engine Oil for BX2350 #9
Think what you want, know that your ignoring the advice of people who go to seminars and classes on this kinda stuff, and hear lectures by the engineers who work up the formulations of the oils. Yes, Kubota, New Holland, Deere or whoever is not out pumping oil. They do however use blends that are very different than whats used for on road machines. As was said, tractors typically work at 80-100% of their ratted load, cars are trucks are typically at 20-30%. If you went and ran a pickup at 100% load the engine would burn up after a few hours. Tractor Trailers would be running similar blends to what you see in tractors, and likely at similar expense (if not more). Most of their trucks are using cummins/fleetguard fiters which are not cheap. Thus... stopping at Autozone for the stuff to service your tractor is not a good idea.
   / Engine Oil for BX2350 #10
I was talking about tractor trailers... and their oil is NOT that expensive! Like i said there are fleets out there that has their oil tested periodicaly to make sure the oil is doing its job and they can tell ahead of time for pre muture wear or a malfuntion. These fleets depend on the BEST oil and depend on the oil to get the maximum life out of their engines because rebuilds cost $10K at a minimum. Regular motor oil wont cut it because of the friction modifiers and detergents that are added to it. These fleets use rotella, and at $8 bucks a gallon and $15 bucks a gallon for synthetic at walmart, you cant beat it. But if you want to listen to other people at seminars and at the dealers telling you what they want you to here then go ahead, thats up to you. How about do your own research and find out some facts without putting your faith in what someone wants you to believe. For example, They could be using rottella and adding a additive to make it theirs and claim its the best because of bla bla and put a big o fat price tag on it. Again, I aint saying kubota oil aint no good, thats not my point! just it isnt any better than what already out there, especially at their premium. ALso everyone dont have a dealer that close to them anyway. Everyone has their own opinion what they like.
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2000 Genie Z45/25 Manlift (NOT RUNNING)(TITLE) (A50774)
2000 Genie Z45/25...
2021 Ford F-150 XL (A50120)
2021 Ford F-150 XL...
