Engine oil drain plugs
   / Engine oil drain plugs #1
NewToy
Veteran Member
Ohio
'05 Farmtrac 270DTC
My Farmtrac 270 is equipped with a Daedong engine so I thought you guy's might enlighten me. While removing the two drain plugs for the engine oil I noticed they were not installed very tight from the factory. Also, there is a thick rubber washer under each plug. How often do you replace the rubber washers? Is there a torque value for the drain plugs?
I appreciate any info.
Thanks,
John
   / Engine oil drain plugs #2
All too often oil plugs are put in 'way too tight', and they don't need to be. Don't want to mess up the threads in the oil pan.
Snug is what I do. Of course, don't want to lose one either. /forums/images/graemlins/tongue.gif
   / Engine oil drain plugs #3
You would replace the washers if they become thinly compressed, or start cracking. You only need enough tightening to stop leaks, don't over do it as stated already. Simply snug it down, run the tractor and check for leaks. Tighten a little more if needed.
John
2007 JLG SkyTrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
International 1420 Combine (A50514)
International 1420...
PALLET OF MISC HOSES (A51244)
PALLET OF MISC...
