engine kill problem
   / engine kill problem #1
beoldi
COLORADO SPRINGS
ls 2030 h
ls 2030 model tractor starts fine,bucket hydraulics work normal.. when i press accelerator pedal OR turn on pto, the engine INSTANTLY stops.. This problem occurs randomly.. It can go weeks with out occuring or the next time i crank it up !! Definately not a switch. It,s hydraulic pressure problem .. The hst transmission has it,s own pump, the bucket it,s own pump. My accelerator pedal get,s harder to push when this problem occurs.. Problem leaves after awhile ,,minutes to many hours later !!!! Is there a pressure relief valve somewheres? Any help will be appreciated. Tractor has only 155 hours on it !!!ALL maintenace is up to date !!
found problem !!! My instrument panel was internally shorted. Everything runs tru it. Engine tac,etc,etc, cost $140.00 part.
   / engine kill problem #3
Ahh! Hydraulic pressure problems take many forms. ;-)
Those "free electron" hydro systems are the worst. ;-) Pressure and flow... Volts and amps, ......
Your up and going, that's what counts!
   / engine kill problem #4
Was this not covered under warranty, and if not, why?
no, 5 year warranty only covers INTERNAL components.
2016 Chevrolet Impala Limited (A50120)
2016 Chevrolet...
2015 Chrysler 200 (A50324)
2015 Chrysler 200...
2016 MACK (A50323)
2016 MACK (A50323)
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
