engine kill problem
   / engine kill problem #1
beoldi
COLORADO SPRINGS
ls 2030 h
hello guys, i am a good wrencher etc , but have a)(sporadic) problem with a 2030h LS tractor. here is symptoms WHEN problem occurs. When accellerator pedal is depressed it INSTANTLY kills the engine. My seat switch has been bypassed . the engine restarts fine. to get going again, i move all shift levers ., work bucket etc etc NOTE: If i turn PTO selector knob to MID PTO etc, this also kills engine!!! The 2030h has a hydrostatic transmission.. MY thoughts are a HIDDEN switch somewheres. Any help would be appreciated. THANKS IN ADVANCE. PS. IT has 150 hours on it!!
   / engine kill problem #2
I haven't looked to see if the seat switch is normally open or closed. Did you take your Ohmmeter to determine if the switch is working? In the end of the terminal, does it have a shorting clip? It sure sounds seat switch circuit related. It looks to be normally open.
A quick check in the manual says:
Tractor will not remain running with operator present in seat
Faulty seat switch• Test switch, replace if necessary • Blown #1 10-amp fuse• Replace 10-amp fuse • Blown #2 10-amp fuse• Replace 10-amp fuse • Faulty safety controller• Test controller, replace if necessary • Faulty fuel shut off solenoid• Test solenoid, replace if necessary • Improper ground• Check ground location, for clean contact area
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2008 John Deere 6330 Premium with Trebro Sod Harvester (A52128)
2008 John Deere...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2018 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2018 CATERPILLAR...
UNUSED AGT QUICK ATTACH DROP HAMMER (A51244)
UNUSED AGT QUICK...
