engine help old lb1914
   / engine help old lb1914 #1
truckfix
kioti lb1914,kubota8200
hi ive finished rebuilding a td 950 out of a lb1914. went together nice . i'm at the stage of putting the valve train together and putting the flywheel on.now the manual is very vauge on a few things. on the flywheel there are marks for each cylinder tdc and also fi for each cylinder.the flywheel can be bolted on in any potion so how do you line this up so when the engine is placed back in you know your timed properly to match the inspection hole in the cluth housing.a the engine is on tdc 1 cylinder . ive never rebuilt a diesel so im used to external timing marks on gas jobs.any help would be appreciated.will buy a runner next time.
   / engine help old lb1914 #2
I know this is an old question, but flywheel should only go on in one orientation. The bolt hole locations will not allow you to screw it up and get them all in. If it went on first try you just got lucky.
2015 DODGE RAM...
71059 (A49346)
71059 (A49346)
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
John Deere 4640 Tractor (A50514)
John Deere 4640...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
