Snow Engine heater YM1700
   / Engine heater YM1700 #1
DaveUK
Sweden
YM1700
So I've made a front snow plough, but now turning my attention to some form of engine pre-heat. It was a bit of a pig last winter, although the TS would get it going.
The engine doesn't seem to have any accessible core plugs, and the bottom radiator hose is a bit tight to get a heater in, plus all the heaters I've found are bigger diameter.
So what are my options? I thought about making a cover to go over the front/bonnet/sides and put a fan heater or similar underneath, or maybe a heater pad on the sump. Any ideas?
   / Engine heater YM1700 #2
Do you have pictures of your plow build? I'd like to see those.
I don't know anything about cold weather, really, but am familiar with products like this. They come in various sizes and styles, and are magnetic, so with a pair of them you could stick one on the crankcase and another on the head or engine block, and have the lubricating oil pre-warmed, and the engine coolant warmed up too. I don't know how junky that particular product is versus others.
Somewhere around that page I saw thermostatically controlled plugs, which were intriguing to me. If you stacked them with a timer or something, it would automatically turn on if it's a certain time and temperatures are colder than specified.
   / Engine heater YM1700 #3
Get a dip stick heater ...they work good and are a simple install... remove your oil dipstick and insert the dipstick heater. Just remember to unplug the heater before driving off.
   / Engine heater YM1700 #4
When my block heater blew I resorted to a magnetic that I got in a yard sale.
OK, it helped a bit but only after 6 hours of heat combined with a 4000 watt construction heater blowing hot air.
The magnet types just do not have the wattage.
From my experience a minimum of 400 watts is needed and I'd really like 5-600.
The magnet types seem only available in 200 watts and I wonder if even 100 watts gets to the oil.
Long story short, no fun changing a block heater at minus 20deg.
   / Engine heater YM1700 #5
A tank type water heater that goes in a heater hose on a car may be the only solution but hooking it up will take some imagination.
And IMO a 1500w is what it takes to do a good job pre-heating an engine in below freezing temps and it doesn't take long either. No reason to run it all nite unless you want to or have a timer that will handle that much current.
   / Engine heater YM1700 #7
I used a heater in the lower radiator hose when I had my YM1700. The heater was about 4" total but the hoses slid on 1" on both sides. So I really only cut out about 2" of the hose. I have no idea what brand it was anymore. I think it may have been for a 1 1/4" hose.........?
   / Engine heater YM1700 #8
I Just bought a 300 watt exterior magnetic mounting block heater; the size of a sardine can; and can be perminantly mounted with metal straps; or just take off after 1 hr and start and go .... $40 Can on sale ...
   / Engine heater YM1700 #9
400w is plenty if you can get it in the block or a lower hose but the external clamp on and tank type circulating heaters need a lot more watts to do the same heating a block type will simply because they are heating the air around them too.
   / Engine heater YM1700 #10
I hope it actually works like that for you Dave!
However I have my doubts based on my experience with magnetic type heaters they may have their place but I have not found one on a tractor. I had a 200w once and it didn't do a dang thing stuck to my oil pan which is a flat plate and should have been ideal for it to work heating the oil and it did absolutely squat.
2016 JOHN DEERE 135G (A52472)
2016 JOHN DEERE...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
1997 Freightliner FL60 Truck, VIN # 1FV3GJBC6VH725847 (A51572)
1997 Freightliner...
