Engine error light 1538
/ Engine error light 1538 #1
metalcaster
SW Michigan
Mahindra 1538
The engine error light began flashing Saturday afternoon. I have 186 hours on the unit and put in 2-1/2 hours of using a brush cutter to cut a couple acres of full growth grass on Friday evening with out any errors. The fuel level was pretty low when I started it and move a trailer around the yard some and shut it off until I could get more fuel. Got a can from the same station that I've always purchased the fuel from and transferred it to the tractor's tank . Added a few ounces of the diesel additive recommended by my dealer. I then used a power washer to clean off the hood and around the axles and operator floor area; did not spray the engine area. When I started it I noticed the flashing light.
Ran it just a little today (5 minutes) thinking that maybe there is a bit of air in the fuel system that may work it's way out? BTW it was low on power for those 5 minutes. Any suggestions other than trailering it to the dealers next week?
/ Engine error light 1538 #2
Check with the dealer to see if there is a ECU update available for your model. They can perhaps reflash it, and you'll be off to the races. I believe that a handful of 2538s and maybe the 1538s as well were showing a phantom "high common rail pressure" error. After 50 of those false readings they may go into limp mode. (Which is possibly why your power is reduced.) If this is what it is, then the programming should fix the bug.
Perhaps not related to this, but I thought I would share what I had heard. Good luck!
/ Engine error light 1538 #3
It could be related to the low fuel. I found that it will pitch a code during the 50 hour filter replacement when I changed both fuel filters. After changing the filters and priming it started and ran a few seconds then shut down and pitched the CEL and code. I figured an air bubble was in the system so I reprimed and it started up again after a bit of cranking. After another restart the light self extinguished. Without knowing what your error code is there is no way to give you anymore insight.
I suggest you get yourself an OBDII code scanner. This will let you read engine trouble codes and reset the check engine light on your own. They are worthwhile having as you can the same code scanner on your other vehicles.
BTW I did a write up in the filter changes so if you haven't yet, I suggest you give it a read as the manual will lead you astray. Hopefully with 186 hours on your machine you've already done the filter and fluid changes.
BTW if your temp gauge is inop, that is indeed bad ECU programming and your ECU will need to be reflashed to correct the error and get your temp gauge working as it should. I have a 1538 and mine required a reflash for the temp gauge to function. I haven't seen any other ECU problems at 50 hours. Other problems due to poor workmanship and slipshod work habits at the distributorship (West Coast) but nothing else that was ECU related so far.
I noticed today that Mahindra doesn't use weatherproof connectors every place you'd think they would. For example, today I noticed the connector for the PTO switch is a cheesy and cheap Amphenol connector that is open to the elements not a weather pack connector as it should be for a machine that is out in the weather and exposed to the elements. Something like that could possibly be related to your washing your tractor. Maybe it'll clear up after it's had a chance to dry completely.
where is OBDII port? Not mentioned in the manual.
/ Engine error light 1538 #5
LOL nothing else is either. You'll find it flopping around loose on the left side engine harness. It is not mounted as you'd expect it to be. Mine was tucked behind the harness so feel around the harness and you'll find it. It's just like the one in your car so you know what to look for. As I recall there were only two or three wires to the connector.
Picked up a scanner today from HF. 25% off coupon from their webpage good for only today made it less painful. And to have it on hand, like dickfoster mentioned, is a good tool to have anyway. Original connection said 4 codes, and since I didn't read the manual (just another person's opinion of how to run something) I cleared them prior to reading what they were. Ended up with a P1801 and $7E8. Selected Mitsubishi as manufacturer as Mahindra was not an option on the reader.
Also tried the primer a few times code still evident. Looks like I'll be taking a trip to the dealer later this week.
This is the second long holiday weekend that this tractor has thrown a code. Last one was Labor day when the engine temperature sensor went bad. While I don't have as much that has to be done this weekend as on Labor day, it sure sucks not having this thing running properly so that I can do something with it.
Called my local dealer and talked to the service manager. He suggested changing out the fuel filter before bringing the unit in. Another owner brought theirs in and it was nothing more than the filter which is not warranty item. Owner was a bit mad that the service was not covered. I will change the filer and see what happens. I'll also ask about a possible ECU re-flash when I'm there.
/ Engine error light 1538 #8
Are you sure the temp sensor went bad. When my tractor was new, my temp gauge didn't read anything. I located and checked the sensor with an ohm meter and found normal reading with what I'd expect. It turned out to be faulty ECU programming from the factory requiring a reflash. The temp sensor feeds the ECU, the ECU then feeds a microcontroller in the display panel that runs the temperature display.
Be sure to read my post on changing the fuel filters, there are two of them. It may just save you some grief.
As far as the sensor, I'm basing that on what I was told by the service manager. They changed the sending unit and all was fine. Since then there has been movement on the temp gauge from time to time so it is functioning.
I copied your filter change post to a word file, printed it out and placed it in my manual. Also saved a copy to my Onedrive. The instructions did help. I removed the loader and I do think that it may have been easier to see and access with it off. Did not remove the splash shield though.
My dealer has 4 locations and shares a Mahindra code reader among them. I suggested they start building a reference table comparing what a code that a standard OBDI reader provides vs. the Mahindra reading. Maybe get faster servicing by using a reader that is cheaper and readily available. Maybe someone else has already done this?
Well the code that I was able to retrieve was P1801. Gave that to my dealer's service manager and he contacted his Mahindra rep. Rep asked how did you get that before the TSB? Anyway they had me bring it in for an ECU reprogram. It seems that the key needs to be on for 5-8 seconds before starting for the ECU to complete the boot sequence. If done too many times it errors out and throws the CEL. We will see if this corrects it.
/ Engine error light 1538 #11
Don't know if it's right for Mahindra but I get "Transmission Clutch Interlock Safety Switch Open Circuit" when I searched that code on the Internet.
Yea, everything I saw on the web with that code was the same. I removed the and the base between the fenders and looked for any swithes / wires that I might have gotten water in and of course found nothing. Did notice that the hydraulic fluid was a little low so I topped that off. There is a little leakage at the quick connects on the front of the loader for the grapple. Since I've not heard from the service manager yet, it will probably be tomorrow before I can pick it up.
Picked up the tractor yesterday and all is good again. In addition to clearing the CEL, as Dickfoster commented, the temperature gauge actually shows a bar soon after starting. Back to putting this thing to work.
/ Engine error light 1538 #14
Since they reflashed the ECU to fix my inop temp gauge, mine settles out around half scale after getting up to normal operating temp or about where you'd expect it to run.
/ Engine error light 1538 #15
Hello? Is anyone still alive in this thread? I'm curious to meet the group of you guys (DickFoster, Metalcaster and whomever else). Anyhow, I have a 2016 1538 HST Cab and I had my tractor throw the "Engine System Failure or Malfunction Indicator" light on my dash. The tractor has 840 Hours on it, has been serviced in the past however what happened recently was I was snow blowing up here in Northern Ontario Canada and suddenly my power reduced drastically. This returned to normal and everything went along for a day...then it happened again and this time it returned to full power when I reduced power but slowed again. The dash light lit up, I shut off the machine and after a little while started it the light cleared. Away I went and used it for a bit and the power loss came again and so did the light. Now the light was on continuously each time I started the tractor.
Anyways, upon checking things under the hood I found that my DOC can and the exhaust bolts were missing? The DOC canister and exhaust pipe were flopping around! I though hmm wow ok and re bolted them up and expected a change to the tractor but it still has these issues. My friend has an OBD reader and we connected it and didn't get any codes (assuming not all OBD's work). Anyways the tractor finally was delivered to the dealer and they found pine needles in the fuel line and fuel filter is somewhat dirty. We're thinking that this will be the fix but I'm skeptical! Also my float feature isn't working (if you push forward on the joystick it will totally lift the implement?). They said they'll replace a part for that feature at 250 dollars Canadian.
I'm hoping my tractor has the flashed ECU you guys are talking about! Can I buy a certain OBD reader and use it successfully on my tractor?
Thanks Roger.
/ Engine error light 1538 #16
Thanks Roger.
I've been following this thread and I'll add my 2 cents. I bought a 1533 gear new from a dealer who has since dropped the Mahindra line. Out of warranty, the MIL light started flashing and has been every start up for over a year. I have not experienced the power loss that appears to be a "limp in mode". Having a few scan tools, I tried each and always pulled the P1801 code that, even the high priced scanner does not define. The Google definition related to a transmission is, I believe, a Hyundai OEM code and will not apply to other makes. I use the generic OBDII setting and let it autoscan to connect to the correct protocol. An out of state dealer told me about a problem with the EGR and, on a hunch, I changed the valve, a very expensive mistake. An in state dealer warned about giving the ECU a few seconds to boot up before engaging the starter. even though glow plug operation would probably be warranted in the sub-tropical climate here. To my knowledge, this is the only Bosch ECU application that has this requirement. Like Dick Foster, I also looked at the ECT sensor and bench tested both the sensor and thermostat. Thermostat was spot on and the sensor returned plausible information which I have charted. Conclusion, the ECU needs the reflash. I am able to connect the scan tool for live data with some being plausible and some worthless. What ever is turning on the P1801 code is a continuous fault code and it doesn't clear when codes are cleared. I have purposely introduced other faults to verify that the scan tool does indeed clear codes when commanded and all will clear except the P1801. BTW, tinkering with the EGR also set the amber trouble light. Because my P1801 appears with KOEO, it can't be related to rail pressure unless it is a mode 10 code that will not clear with a clear code command from the scanner.
My latest project was to identify all the circuits and wire colors at the ECU to use in future diagnostics and to identify exactly what inputs and outputs are connected. Any comments or corrections to my observations will be a welcomed help.
2016 Komatsu HM400-5 44 Ton Articulated Dump Truck (A60352)
2016 Komatsu...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
Industrias America Loading Ramp (A60463)
Industrias America...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
CATERPILLAR 289D3 SKID STEER (A62129)
CATERPILLAR 289D3...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
