engine electrolysis
   / engine electrolysis #1
Iceworm
Wasilla, Alaska
Usually red, they run better
I havn't seen much about engine electrolysis on the forum. I have been using ph test strips and a ph balancer. Anyone else have anything easier? Here in Alaska, it doesn't seem to be a large problem but we use 50/50 antifreeze mostly year round.
   / engine electrolysis #2
Honestly, I dont have an answer for you... But in my experience and from what I know about it.... You only have electrolosys issues when there are dissimilar metals in the cooling system.. Meaning cast iron block w/ Aluminum heads (or heater core in my experience).... The coolant flow across the dissimilar metals actually creates a voltage.. This volltage wants out... It will find a path, hence the holes in components.. Others may have better explanations and stories for you, but since no one posted yet I thought I'd just tell you my take on it and recomend a general web search for cooling system electrolosys...
   / engine electrolysis #3
If you are already using a conditioner ( presumably for PH, cavitation, and electrolysis).. then what are your concerns? Souinds like you are doing it right.
Soundguy
   / engine electrolysis #4
I agree with Soundguy, if you keep clean coolant in the system it will never be a problem. We have checked cars in the shop and seen as high as 5v on a digital volt meter between the block and heater core with worn out coolant. Same car after a flush and fill will show >0.3v.
Jack
Thanks fellows, I just had not noticed any threads on the subject and wondered if there was any common problems I should be aware of. Thanks for your good advice and concerns.
   / engine electrolysis #6
Whenever I change the coolant in my diesel tractors, I pick up a bottle of FW-15 coolant addatave from NH... costs about 5 bucks. You use ti with test strips to keep a 5% soloution.. etc. Prevents electrolysis and cavitation..
Soundguy
2008 GREAT DANE 53x102 DRY VAN (A53426)
2008 GREAT DANE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2008 Toyota Tundra Crew Cab Pickup Truck (A51692)
2008 Toyota Tundra...
90018 (A48082)
90018 (A48082)
