Engine control module file modifications.
   / Engine control module file modifications. #1
ROGERCORBETT
cincinnati, ohio
massey ferguson 1754
Does anyone have any experience with software from GPT Consulting. It sells software and a tuning tool that modifies the engine control module file pertaining to the emission system.
   / Engine control module file modifications. #3
I didn't see anything on the GPT site that would get the file off the ECU or install the new one. That can be tricky. In road vehicles the manufacturer often tries to make that difficult. It may be easier with off road vehicles. I'm suspicious that they offer tunes for so many vehicles. Usually a tuner will specialize in a relative few number of makes. They need to test on a dyno with a vehicle to get it right. The ECU files are not generic, they're specific to the ECU and the model of vehicle.
The going rate for a tune for a car is roughly in the $500 range, plus about the same for the tuner hardware that installs the tune.
I've had some cars tuned. Some of the tunes were CARB approved, some not. When you make a non approved mod one should make sure it's possible to undo the mod.
Bobcat Skidloader Trencher (A50774)
Bobcat Skidloader...
Richie Water Master 1200 Trough (A50774)
Richie Water...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
2014 BMW 328i Sedan (A50324)
2014 BMW 328i...
Piranha P90 Iron Worker (A50322)
Piranha P90 Iron...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
