Engine block/coolant heater
   / Engine block/coolant heater #1
getitdone1
I have a 5020 John Deere, year 1967 and need some way to heat it to make it easier to start. Don't like using starting fluid, but I do.
I find there's several types of heaters. Which is the best?
Tank type
Block type
Lower radiator hose type
Seems the tank type is most popular and all my John Deere dealer offers. $140.00. Pretty high price compared to what I've seen on the internet.
Appreciate your response.
Don
   / Engine block/coolant heater #2
I prefer a block heater that threads into a frost plug, but if an inline coolant heater is easier, they've work well for me and are fairly cheap.
   / Engine block/coolant heater #3
Welcome to TBN!
That's a BIG tractor! With a BLOCK to prove it... :D
I've used both tank heater's and block heater's and I've never seen a 1,200 watt block heater!?!?
But I've got a 1200watt tank heater sitting on my shop shelf at the moment.
They're cumbersome and you need to know which direction the coolant flows but they'll heat that big 5020 alot quicker than a block-insert heater - IMO.
Newer, cars, trucks and tractors are designed to be sleek, with closed up internals. Open the hood and there ain't much wiggle room to do anything with...
You could set up a picnic table with chairs on your 5020! (Just build a shelf off to the side.)
Your dealer is high - if you want to save $50 - go to Wally's or Schuck's.
AKfish
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
Mobile toilet with shower (A55758)
Mobile toilet with...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
2017 Nissan Versa SV Sedan (A55758)
2017 Nissan Versa...
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
