3-Point Hitch Engaging 3point hitch with FEL raised caused engine to get really rough/stall
   / Engaging 3point hitch with FEL raised caused engine to get really rough/stall #1
rmtygart
Fallbrook, CA
Kubota BX2200
I have a Kubota BX2200, and am pretty new to the game. Runs great, no problems until a friend raised the FEL to the top and operated the 3ph at the same time. Engine suddenly got really rough. Once it was shut off and the FEL lowered, and the 3ph raised again, it ran fine. Dealer says it was because the 3ph was "in detent" and the two implements were "fighting each other". Hasn't recurred. Dealer says that those two, the FEL and the scraper attached to the 3ph need to be operated separately, not both at the same time. Anybody experience this?
   / Engaging 3point hitch with FEL raised caused engine to get really rough/stall #2
How about that,another guy from Fallbrook!! I've had 4 different Kubotas and they all have different quirks and what you are experiencing is common.These small tractors just don't have the sophisticated hydraulic systems that you find on construction equipment but they sure beat the heck out of a scoop shovel and wheelbarrow.
Thanks Jim! Good to know there's another Fallbrook guy on here. Good to know that this is not particularly something to worry about. Sounds like you have plenty of Kubota experience. I ran big tractors as a kid, but it's been a long time, so things take some getting used to again. Just got this BX2200 last week from Pauley. It was a trade in. Might go with a new one eventually, but overall I'm pretty happy with this one right now. Mostly use it for moving mulch around the property. Have to get together sometime.
   / Engaging 3point hitch with FEL raised caused engine to get really rough/stall #4
Hmmm I've got a BX2360, basically a more recent model of the BX series, and as far as I know my 3-point doesn't have a detent. Out of curiosity do you remember what rpm the engine was at when you had the rough running issue? I've been wrong many times before, but I have to wonder if the rpm's were to low to support operating both the FEL and 3-point. Just something for you to think about when you're running your tractor. Either way have fun! :thumbsup: They're great little machines and mine's become pretty much invaluable.
He did have it a just above an idle, so that may have just been too much for the engine to handle at low rpms. Other than that one little incident, it has performed perfectly. This seems to be a great little tractor, and perfect for manuevering around our orchard, but big enough to do anything we want to do. Thanks for the info!
   / Engaging 3point hitch with FEL raised caused engine to get really rough/stall #6
What the dealer is explaining is that as the pressurized fluid is filling the "lifting" side of the loader cylinder (to lift the bucket), it needs to "vent" fluid from the "lowering" side of the cylinders. That fluid goes downstream through your rear remotes (if equipped) then through the 3 point valve, then into the tank.
If the lever for the 3 point lever is in "raise" position and the 3 point is all the way up, the only way for the fluid to get to the tank is by getting to 2000ish PSI and going through the relief valve.
That causes the loader and the 3 point to "fight" each other.
Note: This should ONLY happen if you are trying to move the loader and the 3 point at the same time.
Aaron Z
Thanks for the detailed explanation. I'm still getting to know this machine and that is a great help. I will be sure to not let anyone operate both of those at the same time.
   / Engaging 3point hitch with FEL raised caused engine to get really rough/stall #8
Aaron my thanks as well for the hydraulic's explanation. My apologies Rmtygart about the bad info on my part.
   / Engaging 3point hitch with FEL raised caused engine to get really rough/stall #9
Well I have a Mahindra Max25. If I have the 3PH lever all the way to the top (for lifting the MMM) it causes the FEL to essentially operate in reverse. The bucket goes down instead of up. The arms are very slow to rise. But if I put the 3PH lever down farther than the very top the issue goes away.
So it sounds like it is a universal problem.
   / Engaging 3point hitch with FEL raised caused engine to get really rough/stall #10
Yes, its due to having the hydraulics run in series (in an "Open Center" system). The way around it is to use a closed center system, but those are very expensive.
Aaron Z
Kivel Dual Prong Bale Spear (A49251)
Kivel Dual Prong...
1999 Freightliner FL80, 20' Dickerson Winch Bed (A47371)
1999 Freightliner...
Cardinal Aluminum Corn Elevator (A49251)
Cardinal Aluminum...
New/Unused 12ft x 7.4ft x 8.2ft Container (A48837)
New/Unused 12ft x...
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A46683)
2025 Kivel 48in...
Tong De-Stoner Bucket Stand (A47369)
Tong De-Stoner...
