Engaged Starter when Tractor was running.. Aghh!
   / Engaged Starter when Tractor was running.. Aghh! #1
italyguy01
Pa
X485
Hello all! I have a John Deere X485. For the first time ever, I accidentally turned the key to engage the starter when the tractor was already running. Of course got the loud screech and instantly let go.
I am wondering if anyone else has done this, and how much damage was done to the flywheel and/or starter gear? Is the starter gear more likely to be damaged then the flywheel? I'd hate to have damaged the flywheel.
Darn....!!! I take awesome care of the tractor and this just eats me up!
Thanks!
   / Engaged Starter when Tractor was running.. Aghh! #2
Don't do that too often.
   / Engaged Starter when Tractor was running.. Aghh! #4
It happens, I wouldn't worry too much about it.
Thanks DT86. IS the flywheel a harder metal then the starter gear? Just curious if the starter gear would chew up before damaging the flywheel? (Easier to replace starter then flywheel). Aghh Still can't believe I did it!
   / Engaged Starter when Tractor was running.. Aghh! #6
Yes, typically the starter drive is made of softer metal than the flywheel.
Like DT86 said, don't worry about it.
   / Engaged Starter when Tractor was running.. Aghh! #7
I couldn't tell you how many times I've done it, usually in my girl friends Civic. It's the only non diesel I ever drive, I'm used to being able to hear the rumble of the oil burner to tell if it running or not. I'll jump right in and hit the key since I don't hear it and she's already in and got the heat/AC going. Opps!
Thanks guys, I appreciate it!
   / Engaged Starter when Tractor was running.. Aghh! #9
Yep, I've never done that to a tractor, but I've certainly done it to cars, and as far as I know, never damaged them, but I sure don't like to do it.
   / Engaged Starter when Tractor was running.. Aghh! #10
the one way sprag clutch takes most of the abuse ... the starter teeth take a bit too. don't worry too much :)
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
BACKHOE BUCKET (A53843)
BACKHOE BUCKET...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2012 C.GALLEGOS 130BBL (A53843)
2012 C.GALLEGOS...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
