The lever should select the proper PTO speed, (Don't over speed the snow blower)... Neutral should stop the PTO. Also that should have a 2 stage clutch, when you push the clutch down, the first stage clutch should stop the tractor, then as you continue the second stage will be at the bottom of the clutch petal travel... that should stop the PTO... KennyV
