Emergency exit from storm shelter (dedsign problem)
/ Emergency exit from storm shelter (dedsign problem) #1
Gitche Gumee Kid
Bronze Member
NW WI
IH 284
A question that is a follow up to my emergency storm shelter exit,(5/12 /13).
I have 50' of 60"" corrugated pipe for the project on order. It weighs in at 55#/ ft. I'll get three sections. Ideally I will get 17 ' sections.
Question. What's the best technique to safely handle large diameter pipe?Can an attachment be fabricated to more safely handle the pipe? I have a
IH (model 374 )tractor/fel and a mini excavator ( Takeuchi TB016 ) both have a lifting capacity of approx 1000#s . Would wide nylon slings be best?
TIA
GGK
/ Emergency exit from storm shelter (dedsign problem) #2
I have lift longer sections of culvert but a lot smaller and lighter then you are looking at. I used a 16' length of 4x4 hung off the excavator bucket. With the beam hanging level it was quick and easy to grab a section of pipe move it to and lower it in the ditch. Both ends of the 4x4 had short lengths of chain with hooks that I used to grab the ends of the culvert.
The photo is one I grabbed off the net.
/ Emergency exit from storm shelter (dedsign problem) #3
We throw a strap around the middle of it and adjust it to hang level .
/ Emergency exit from storm shelter (dedsign problem) #4
I had a lot of pipe to install so the beam was quicker once leveled. For three sections depending on how much room you have either way would work.
10in Digging Tooth Bucket Excavator Attachment (A60352)
10in Digging Tooth...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A59904)
2013 INTERNATIONAL...
1997 Sherman and Reilly Drum Line Puller Tensioner Trailer (A59228)
1997 Sherman and...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
BUNDLE OF 3'X20' CORRUGATED METAL SHEETS (A60432)
BUNDLE OF 3'X20'...
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
