Eliminating the FEL quick disconnect
   / Eliminating the FEL quick disconnect #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
I want to remove the FEL Quick disconnect by making new a hose to go straight to the diverter valve. Is this going to cause any problems?
Harold
   / Eliminating the FEL quick disconnect #2
only that it will make it hard to connect additional hydraulic equipment. I have not seen a hydraulic pump failure on a non-loader equipped Jinma (I suppose it could happen) the factory quick connect being there in itself does not seem to present any problem.
There is a problem when you introduce a loader with different style of quick connect fitting...Or if you run the engine with this connection disconnected.
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51247)
2012 VOLVO DBL...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2005 Manac AAF-48 50 Ton Flatbed Equipment Trailer (A51692)
2005 Manac AAF-48...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
23311 (A51694)
23311 (A51694)
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
