JDgreen227
Super Member
Was coming home from the local grocery store and stopped behind a late model Jeep that had a huge spare tire hanging on the back end...reminded me of the column a Detroit Free Press auto writer recently authored about automakers wanting to eliminate spare tires.
He wrote, quote: "Automakers are concerned with saving GRAMS OF WEIGHT...." (emphasis added) so they want to eliminate spare tires...."
So I contacted him: "I just put a 1995 vintage, full tread 1995 F-150 STEEL RIM with a mounted and fully inflated P235-75R 15 tire on a scale, and the weight was 66 pounds. According to my research, a new 2012 F-150 20-inch tire and ALUMINUM rim weigh over 85 pounds. So, if automakers are so concerned with saving "grams of weight" as you term it, why don't they use 15-16 inch rims and tires instead of 20 inch? Can you imagine the grams (actually POUNDS) of weight saved by using the smaller size, especially if mounted on an aluminum rim, rather than the steel one I used as a comparison? Additional benefits would be much less unsprung weight, and the cost of 20 inch replacement tires is obscene."
My wifes brother-in-law recently replaced the 20 inch OEM tires on a 4 year old Silverado---$350 each. That is more than DOUBLE what a 16 inch tire would have cost, and the quality OEM tires only lasted 52,000 miles in conservative driving.
The auto writer actually agreed with me !!!
