Eletrical
   / Eletrical #1
john4nh
TEXAS, CROSBY
CASE 580 BACHOE JOHN DEERE 920 AND 820 FARM-ALL CUB
Anybody know the wattage needed for a generator to run a 30amp travel trailor? Thanks
   / Eletrical #2
John, it'll depend entirely on which and how many appliances you have running simultaneously in that trailer. Just a basic rule of thumb: 30 amps times 120 volts = 3600 watts. When we lived in a 32' trailer, I had a 4500 Kohler running on LPG, so they tell me you lose 11% converting from gasoline to LPG, and I wanted a 4000 watt generator; never had a problem running the clothes dryer, air-conditioning, TV, and coffee maker at the same time.
Bird
   / Eletrical
Ok thanks
We have a 3500watt so that ougtha work. More concerned with being able to run a/c.
   / Eletrical #4
Yep, that ought to do just fine. I don't know what size your A/C is, but it won't be too big. We had a 15k BTU unit on our trailer. And in '73 we used to run a 10k BTU A/C on a little Winnebago with a single cylinder 2500 watt Onan.
Bird
   / Eletrical #5
John,
Bird's calculation is right on unless that's a 220 plug you're talking about. If that's the case, double Bird's estimates (to 7KW).
Of course, it's seriously doubtful that you'd be pulling at maximum. Just calculate what the individual loads are, and go from there.
The GlueGuy
   / Eletrical #6
Start up is your biggest obstacle. A 3500 watt generator won't hardly start capacitor start type motors over 1.5hp. For your situation, getting the AC going will be the test. Most generators have the ability to put out an excess of the nameplate rated watts for a short duration.
   / Eletrical #7
Of course you're right, Bill, but I didn't go into that because he said "travel trailer" and that was my principle hobby for a lot of years, so I know he ain't got any 220./w3tcompact/icons/laugh.gif
Bird
   / Eletrical #8
Remenber that most generators are 'marketed' with their peak wattage. eg. most 3500w generator can only be run at 80% of their rated 3500w peak load continuously. Look for the Load Factor (LF=0.8 means 80% sustained) or words like continuous duty. Some really cheap generators have 50% LF. Comercial generators like honda's indistrial line are rated at 100% LF. Thats why they cost 2x the price. The best method is to add up the needs of all you appliances, including starting currents, and choose the right generator accordingly.
Hope this helps.
-Roger
Kubota ZG327 (A50120)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2011 VANGUARD 53x102 DRY VAN (A53426)
2011 VANGUARD...
2008 GREAT DANE 53x102 DRY VAN (A53426)
2008 GREAT DANE...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53473)
2012 RAM 5500...
2015 Chrysler Town and Country Van (A51694)
2015 Chrysler Town...
