Eletrical problem?
   / Eletrical problem? #1
pvcman1
bridge lake bc
mccormack international434
Have a new holland workmaster 55 and i am having problems with the gauges and indicater lights working intermitantly is this a ground problem and where would i find the ground wire? Thanks
   / Eletrical problem? #2
It is likely a ground problem and you may not find a ground wire as such. The plug providing power and signal to the gauges could also carry the ground. The instruments may be grounded by the screws holding them to the dash. Your solution is likely step by step troubleshooting with some cleaning and tightening along the way. Of course it could be a flaky ignition switch, too.
   / Eletrical problem? #3
Electical problems are like a case of HEMORRHOIDS! something we
can do very nicely without however check all wire co;nnections expecially
the battery cables and then ohm them to make sure they are solid.
willy
   / Eletrical problem? #4
Try taking your ground strap off the battery. Clean both ends and if needed wash with a baking soda solution. Then replace. Also if needed shine it up using a wire brush so you have a good connection.
2015 VOLVO VNL TANDEM AXLE DAY CAB TRUCK (A50505)
2015 VOLVO VNL...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A50505)
2019 KENWORTH T680...
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000LB Crane Service Truck (A48081)
2019 Ford F-350...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2020 Chevrolet Express 2500 Animal Control Cargo Van (A48081)
2020 Chevrolet...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
