I'm planning on installing a Mighty Mule automatic gate about 500 feet from an existing 200 amp panel that currently runs an irrigation well, 110V outlet and an irrigation timer but will power a shop at some point in the future (the shop will not be near this panel so the power will have to be run from there to another part of my property when the shop is built). My options for powering the gate seem to be to run the Mighty Mule low voltage wire (about $200) from the gate to the outlet near the panel and plug in the transformer there. Or I could run another 110 line 500 feet to the gate and plug in the transformer near the gate. It might be nice to have power near the gate to run a light or intercom in the future, but not really necesary. Any idea what gauge wire I would need to run for a 110V outlet 500' from the electrical source- and can I just direct bury the wire (either the low voltage or the wire for the outlet) or should I use conduit? This project is all ready running into more $ than I anticipated so would like to keep it inexpensive if I can. I'm no electrician- but this would just be wiring in a breaker to the exisiting panel and then wiring an outlet on the other end, 500' just seems like a long way to go. Any advice appreciated.
