Years ago, our substation transformer test station had, instead of wire, copper pipe carrying the current. It looked just like what carries water in many houses.
Transformers are AC, of course, so the reason they did that was the pipe is rigid, and will support itself, and the reason for pipe instead of copper rod is the center of the rod would do very little anyway, since due to the skin effect, the center portion of a solid copper rod carries little current anyway.
It's true. If I give you a 1/4" solid copper rod, it is a solid conductor for DC, but you might as well consider it a hollow pipe for AC, because it is, and you can't do much about that.
I wrote the reason why, but I erased it...if you care, read up on the "skin effect" until your eyes hurt. But in my experience, it is far better to make sure you know what a multi-meter is, how to use one, and what all of the tests mean, and how to troubleshoot the real problems you will encounter in your lives with a good multi-meter. I think I have seven multi-meters, and I never leave home without one in my car. I have clamp on probes for AC and DC current measurement.
Radio Shack has one for around $50 bucks that does most things, and even does clamp on AC and DC current. Heck, I used to have to spend a fortune to get a meter that will do clamp-on ac current measurements. Now I own two personally...one I gave $400 dollars for years ago, and my Radio Shack one. The cheap purchase means I can actually use it any time I like without fear of ruining a $500 meter.
