HCJtractor
Veteran Member
- Joined
- Jan 28, 2009
- Messages
- 1,519
- Location
- upstate South Carolina, Greenville
- Tractor
- Kubota M6800, Massey Ferguson 240
The more I read, the more confused I am about what I need for my Miller 211 Welder, which is a dual 120 or 230 V, supplied with two plugs. In the 230 V mode, it appears the Amperes Input at Rated Load Output is 24.3. Ideally, I know a dedicated 50 amp breaker is ideal. However, my shop already has a 30 amp circuit, although with a different style plug. My question is can I make a short extension cord to be used as an "adapter" with a 20 amp male plug on one end and a Nema 6-50 female on the other, using appropriate heavy cord? This way I could leave the shop wiring as is.
I am wondering if there is an alternative to running an entire new 50 amp circuit to be able to use this welder in the 230 V mode.
