Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,950
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've got two 250' unopened rolls of normal "in wall" 12/2 wg. I'm pulling wires across my basement so my brother in law (electrician) can hook them up but, skip the pulling part.
He's out of town right now AND isn't answering his phone
In addition to the above, I have probably another 200' of 12/2 w/g UF wire that is left over from putting some lights outside. The wire has been opened and thrown around a bit but never really abused or kinked.
I KNOW that UF can be a pain in the posterior to work with so let's not even worry about telling me that.
My question is, would'nt I be just as legal if I ran the 12/2 wg UF wire inside my walls instead of the normal 12/2 wg?
If I can do that, I not only get to use up my dead in the water UF wire but might be able to return one or both of my 250' (still wrapped) bundles of 12/2 wg wire and get some cashola back.
Since I can't find my brother in law, I've already pulled two runs across the room, cut the outer sheath off the box/switch ends so the outer sheath goes INTO the box, protruding maybe 2/3 inches inside the box. Then it's black wire, white and copper (black/white are still covered)
I don't really want to put 3 more runs across the room unless I know it's a one way street and I'm done. I don't really want to rip it all out and have to put the 'normal' 12/2 wg in its place.
Logic tells me it MUST be ok to use from a code perspective, just a pain in the hiney to use so only stupid people ask about doing it
