ELECTRICAL PROBLEM W/TN75A
/ ELECTRICAL PROBLEM W/TN75A #1
WHITMAN NH
WHEN I FIRST PURSCHASED THE TRACTOR I HAD ELECTRICAL PROBLEMS. IT WOULD NOT GO FORWARD OR REVERSE (SHUTTLE SHIFT). I TOOK IT TO A NEW HOLLAND DEALER AND THEY SAID THEY FIXED IT. NOW IT BLOWS THE FUSE THAT RUNS THE TACK, FUEL GAUGE. THE BEEPER THAT TELLS YOU TO PUT THE EBRAKE ON GO'S OFF WHEN YOU RELEASE IT. SO I UNHOOKED THE WIRES FROM THE ATERNATOR AND IT DOESN'T BLOW A FUSE, EVERYTHING WORKS FINE. SO I HAD THE ALTERNATOR TESTED AND IT IS FINE, BUT IF I HOOK THE ALTERNATOR BACK UP IT WILL BLOW THE FUSE.
I AM HAVING PROBLEMS WITH IT GOING INTO GEAR OR JUST NOT MOVING AT ALL WHILE I AM FEEDING COWS, IT LEFT ME STRANDED THE OTHER NIGHT. THE ENGINE RUNS BUT IT WILL STOP MOVING. PLEASE HELP!!
/ ELECTRICAL PROBLEM W/TN75A #2
If it's still under warranty.. I'd sae it needs to see the 'doctor' again.
While there have been some issues with fuses blowing .. you may want to mention your alternator issue to them so they can check for a chaffed or pinched wire.. etc..
soundguy
/ ELECTRICAL PROBLEM W/TN75A #3
To work fine with the alternator unhooked gives me the idea your problem is in that system but it doesn't seem right.
THE ALTERNATOR TESTED FINE, SO I HOOKED IT BACK UP AND NOW EVERYTHING IS WORKING FINE. IT MUST OF BEEN A LOOSE CONNECTION OR A WIRE WAS PINCHED, I REALLY HAVE NO IDEA.
2023 JOHN DEERE 317G SKID STEER (A62129)
2023 JOHN DEERE...
2015 Komatsu PC360LCLC-10 Hydraulic Excavator (A60352)
2015 Komatsu...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
SD Lanch SDLGC80 Electric Golf Cart (A62177)
SD Lanch SDLGC80...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
