Hello everyone...I got a call from my friend this morning to come over and try to diagnose an electrical issue he was having with an outdoor sump pump. The issue was a burned up plug which I replaced no problem. I am not aware of why the plug would burn up but at the time it was plugged into an extension cord. His sump pump is installed in the concrete under a grate at the bottom of his exposed basement access stairs (It is a finished basement and this keeps the rain water from getting inside). My concern lies with the placement of the outlet which is also in the "pit". The outlet most definately gets soaked with water at times. This circuit has no GFCI at the outlet or at the panel. Am I missing something here? Is there some way that this electrician did this install properly. Has anyone seen this type of setup before? I am just thinking in the event that the float switch fails the water will easily fill the pit submerging the live outlet and creating a puddle people will step in.
