Electrical -- Dashboard Lights Flashing
   / Electrical -- Dashboard Lights Flashing #1
HobbleCreek
Utah
John Deere 4720
The short version:
When I turn the key on my 4720, the dashboard lights flash. Same thing happens if I try to turn on the lights. Nothing else happens. Any suggestions on how to diagnose this problem?
The long version, or, how I probably caused this problem:
The tractor started fine Saturday morning. I drove it across the yard to a spot near the hose bib where I filled up a water tank carried by my front end loader. When I went to start the tractor back up to haul the water to my horses, it would not start. Instead, I got a clicking sound. Although I was confident the problem was not the battery, I tried to jump start it using a portable jump starting device. No luck. I tested the battery and had about 12 volts at the battery. The positive terminal was, however, fairly corroded. I cleaned it with a solution of baking soda and water. No change.
I tested to see that I was getting power to the starter. I was. To test whether I had power coming from the ignition switch, I removed the wire that (I believe) comes from that switch. There was no power there until my daughter turned the key, at which point there was power. All signs pointed to a bad starter.
Because it was the Saturday before Easter, the local John Deere dealer was closed. I decided to put a charger on the tractor to make sure the battery was fully charged in light of the unsuccessful attempts I had made at starting it. I left the charger on and went to the in-laws for some Easter festivities. When we returned that night the charger was still on and indicated that the battery was fully charged (it's one of those "smart" chargers). I noticed, however, that the key had been left in the "on" position all afternoon. I thought to myself, "Maybe I'll be lucky and it will start." I turned the key. No luck (at least not good). Now I have this problem of the odd dashboard lights flashing.
So what do you think?
   / Electrical -- Dashboard Lights Flashing #2
2 possibilities come to mind. First, even-thou your battery shows 12 volts it does not mean it is good. You need to put a load on it and see if it drops in voltage. If you don't have access to a load tester you can try using a voltmeter and turn on all the accessory's and see if you have a drop in voltage, or better yet, bring it to your auto parts store they should be able to test it for you. The other possibilities would be a bad connection from your negative cable at the frame. Make sure that there is no corrosion at the connection. Best thing is remove it and clean it with a wire brush or sand paper. You have mention that you clean the positive post, make sure the negative is good also. Most of the time that I have seen these symptom it was related to a bad battery or a bad connection. Something to start with. Good luck!
Perfect diagnosis Henri. Thank you!
   / Electrical -- Dashboard Lights Flashing #4
:thumbsup:
(1) 10ft Tarter Gate (A48837)
(1) 10ft Tarter...
Earthquake Tiller (A48837)
Earthquake Tiller...
Mobile Military Generator (A48837)
Mobile Military...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A48081)
2017 Mack GU713...
2017 CAT D7E Crawler Dozer (A48837)
2017 CAT D7E...
2005 GMC C5500 24FT. Box Truck (A48081)
2005 GMC C5500...
