Electrical Add ons
   / Electrical Add ons #1
harddock
Bronze Member
john deere 770 4x4
I have a John Deere 770 - I am adding a cab which I would like to have an operatable electric wiper, fan and maybe two overhead aux headlights. Is there any extra circuts built in to the 770 wiring? Or do I need to go from the battery and build another distribution/fuse box?
the charging system I beleive is a 20 amp alternator.
   / Electrical Add ons #3
Hi....On my JD 455 I changed from a 20 amp to a JD 40 amp alternator....however in my case the 20 amp alternator was a permanant magnet alternator with external voltage regulator and the 40 amp alternator was like a regular automotive alternator with built in voltage regulator.
The electric heater is only a little better than 1000 btu's which is really not much of a heater but not bad for a defroster compared to a hot water heater properly plumbed into the cooling system. I have not installed my electric heater yet because I really haven't needed it yet ....but have tried it and the 40 amp alt can handle it.
Thanks.......Casey
   / Electrical Add ons #4
I agree with Casey's point concerning the alternator. The 300Watt (1000 BTU) type electric heater I recommended is sized for UTV cabbed vehicles (like Rangers, Rhinos, Gators, etc.) that typically have 40 Amp (500Watt) sized alternators to keep up with the needed re-charging rate of the battery and support other additional loads (like headlights, cab lights, instruments, etc.)
   / Electrical Add ons #5
You will need to add a new circuit/distribution panel-probably 30 amps and run it through a relay so it's only ON with the key. The factory wiring will not take all that extra load.
I will also suggest you forgo the electric heater and plumb in a heater core to the coolant system if you want/need heat.
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
2018 HMDE TL & 2014 VERMEER (A53421)
2018 HMDE TL &...
