Electric winch to lift dump trailer?
   / Electric winch to lift dump trailer? #1
davo727
Hi, I have been contemplating building a dump trailer and thinking about using an electric winch to lift the front of the dump box , seems like it would be simpler and easier than hydraulic.
Maybe put the winch low at the front of the trailer and run the cable up to a pulley mounted on a heavy duty post and then down to a bar mounted at the bottom front edge of the box. Running up and over the pulley will double the lift capacity of the winch right ?
Im gonna build this to haul 8K of gravel or 2 yards of wet concrete which is about 8K also. Box dimensions of about 4 ft wide, 7 ft long, 3ft deep Should give extra capacity to avoid spilling at 2 yards, box will be 3 yards capacity if filled to rim. Use 2 7K axles. What do you guys think? I have an old chevy dually to pull it. Thanks, Dave
   / Electric winch to lift dump trailer? #2
The pulley system you described gains nothing in lifting capacity, it merely changes direction. To double the pull produced you need a pulley at the top and another at the bottom with the end secured back to the mounting point, or nearby for the top pulley.
You'd also need a pretty tall mast to get the angle needed for easy unloading, if your 7 ft box is hinged at the end then I'd go with at least 7 ft tall mast for the pulleys. Pretty cumbersome, I'd really look into hydraulics if I was doing it:)
You can go here http://library.thinkquest.org/27948/pulley.html and enter 2 pulleys if you aren't picturing the 2 pulley system.
OK thanks guys, On that $550 pierce kit with the hydraulic parts, do you know if they give you the dimensiions or plans of the scissor thing? Thanks, Dave
2006 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2006 ADVANCE...
2022 HAMM H12I SMOOTH DRUM ROLLER (A45046)
2022 HAMM H12I...
SPRINKLER TRAILER (A45046)
SPRINKLER TRAILER...
2020 KENWORTH T800 DAYCAB (A45046)
2020 KENWORTH T800...
John Deere 1025R 4x4 Tractor with Loader (A44391)
John Deere 1025R...
VOLVO 12.1 L FRONT CLIP (INOPERABLE) (A45046)
VOLVO 12.1 L FRONT...
