electric top link
   / electric top link #1
Oldstuff
Missouri
'63 Ford 2000
Is there such a thing as an electric top link? By this I mean one that is electric (12 volt DC) only or an electric motor driven hydraulic cylinder? Would be helpful on a tractor that has no rear hydraulics.
Thanks,
Oldstuff
   / electric top link #2
Isn't this a good application for the hydraulink? From what I saw on the demo video the only thing it can't do is raise the back edge up on something like a box blade when you are on level ground.
   / electric top link #3
Thanks,
Oldstuff
Sort of like a electric screw jack? Several manufactures offer them for lifting smaller dump trailers (like ATV style) - I don't know if they would be strong enough to work as a Top Link but it maybe interesting to look in to if you have the need.
Good luck
   / electric top link #5
I don't know of any but even if there were they wouldn't seem very industrial to me. I would get a remote kit, no more than a couple hundred and then get the real thing:thumbsup:
   / electric top link #6
electric screw jack. Thats a great idea. I never thought of that but imagined a motor that would turn the top link screw.Almost seesm like to would be too easy.Maybe a good idea. The 'screw' part would have to be heavy to ahndle the loads ..
Closest I cam ewas thinking of using the standard top link and somehow mount a cheap electric winch to it. maybe a small sprocket onthe shaft and a chain..Seems as though it would work with plenty of oil on the threads..even if the implimen thad to be placed on the ground to take up some of the weight..
   / electric top link #7
I do think the idea could work, may take a little fabricating of course but don't see why it could not be done. The real problem is I can see it becoming difficult to have a good working system that would be inexpensive unless you could find some of the parts free or greatly reduced. Granted if you had an old screw jack laying around and a old top link you could chop the ends off, don't see why you may not be able to make one? I would also think it would work better on a small machine than a larger one (Cat 0/1 maybe a great test bed)
Found this on the Joyce site -
"Joyce electric cylinders lift and precisely position up to 20 tons, achieve travel speeds up to 546 inches per minute, and raise loads up to 100 inches. They are well suited for industrial environments where protection of the lifting screw mechanism is critical and low maintenance is desired. Requiring only electric power, Joyce electric cylinders may also be used in place of hydraulic cylinders, eliminating the cost and potential for leaks associated with hydraulic systems."
   / electric top link
Thanks to All for replies. I had thought of this because I am assuming to go hydraulic would be complicated or not even possible. My tractor is a 1963 Ford model 2000 and only has the original 3 point lift. Not sure if possible to tap into the existing hydraulic system to add a hydraulic top lift?
   / electric top link #9
If anybody would know what it takes to add rear remotes to that tractor would Soundguy. PM him or post question in Ford section.
   / electric top link #10
Thanks,
Oldstuff
Yes, these are exactly what you need for power. These units are not as big as they look in the brochure and have 3000-5000 lb thrust. The relatively slow speed is precisely what you need for a toplink. They would need to be adapted, but that would not be all that hard. I have one running the bedlift on my Kawasaki Mule and can dump rounded up beds of dirt with it. They can be bought for around $385 complete. With a few more dollars for a directional switch and mounting, they are far cheaper than buying hydraulic remotes and then a toplink to boot. The fact that they run off of 12VDC, makes them very portable. You have to have room for the unit, but you have to have room for hydraulic lines on a regular toplink. This one you only need a wire.
Wacker Nueson Generator (A42021)
Wacker Nueson...
2012 BMW X5 AWD SUV (A42744)
2012 BMW X5 AWD...
2020 Ford Transit Van Van, VIN # 1FTBR1X82LKB60955 (A44391)
2020 Ford Transit...
2007 Ford F-150 Ext. Cab Pickup Truck (A42744)
2007 Ford F-150...
Chery 7' 10 Drawer Workbench (Red) (A44502)
Chery 7' 10 Drawer...
2005 Sterling Acterra Altec LRV55 55FT Forestry Bucket Truck (A42742)
2005 Sterling...
