electric metal shears?
   / electric metal shears? #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
Has anyone tried a set of electric metal cutting shear :confused:and makes from harbor freight? I have a livestock trailer project and need a good way to cut out rust and make a few patches?
   / electric metal shears? #2
I have not.
The other day, I used a shear that attached to a 3/8" drill chuck. It worked great on a cordless. I was told by its owner that the shear was sold in right, left, and center models just like the hand shears. I am not certain, but I recall seeing something similar in a pneumatic tool at Harbor Freight, but I have never seen the drill attachment (looked like pair of scissors) for sale like I used the other day.
   / electric metal shears? #3
Had the HF type for years (black housing model, not the new orange case), worked great. Then broke the blade and went to get a new pair and they changed them. Now I cant find shears to fit mine. Guy I work with has 1 also. When he broke his shears he bought a new 1 and the put the old in the box and returned them. Not something I would do. But he likes his and he makes alot of motorcycle gas tanks so lots of 16 and 18 guage.
   / electric metal shears? #4
Don't know about the HF ones but I got a set from TSC (farmhand) and have used them on 14 gauge without problems. BTW they're only rated for 18gauge. I use a lot of oil (WD-40) while cutting thicker sheets and go a LOT slower.
   / electric metal shears? #5
I have a Bosche cutters that goes thru roofing copper like it was paper.
   / electric metal shears? #6
I have a KT electric shears.
Works pretty good. Just depends on your
specific project needs are at that time.
I don't know that I would use it in your application, but, you sure could.
Several ways to cut out steel.
Shears,
O/A torch
Plasma cutter
Cutoff wheels on a 4 1/2" grinder
Sawsall with metal cutting blade
Probably more, but I can't think of anymore right now.
Whatever you do, where safety glasses or face shield
when cutting that steel. Just don't know what could
go wrong. I have broke many cutting wheels on my grinder,
and when they break, the pieces go flying.
Scary deal, a buddy of mine had a cutoff wheel break. Flying piece
stuck in his caradid artery. He didn't pull it out. If he had, he would have
bled out in a matter of seconds. Left it in, wife took to ER. Emergency
surgury. Minimal damage.
   / electric metal shears? #7
I think a company called Kett has made them years before China copied them. They may have even been the original company. I would look for a set of them, even used off ebay, since you can get parts for them easily. I have a set made by Bosch that's similar and a set of Makita nibblers. The Nibblers work great but leave a bunch of moon shape slivers. I've used them to make a hole in the frame on my Subara to add a trailer hitch, cut through it like butter and can they go in any direction.
   / electric metal shears? #8
Got one Kett on ebay 10 years ago and it still works great.
   / electric metal shears? #9
Speaking of shears I had the opportunity to spot these
Turbo shear - Shop sales, stores & prices at TheFind.com
On my friends worksite. He had this one on hand
Amazon.com: Malco TSHD Turboshear Heavy-Duty: Home Improvement
I watched it in use and seemed pretty kool. Not much different than the less expensive one with the red handle.
But this one allows easy one hand operation.He had it mounted on a 110 volt drill but it has so little resistance that I know a cordless would handle it no problems..Its a bit more than I usually spend on shears but if the budget allows its a good unit.
At one time HF sold a set of three pairs cheap and they well just that cheap...awful
   / electric metal shears? #10
I have 2 Kett shears and a milwaukee.Have had Milwaukee for 20 years and Ketts were purchased at an auction for $10(for both) and one is a little older than my Milwaukee. One stays in shop, one on job trailer and one in spare on shelf. Whichever is closest is the one used. I would say go for it. I'd rather see ya buy a quality USA made(probably older/used) and then parts are readily available.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
74in FEL HD Round Back Bucket (A53472)
74in FEL HD Round...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
