clemsonfor
Super Member
Ok so the time has come to finially get around to this project. I bought it awhile back on sale. Anyway I am putting it into a closet basically across the hall from my main panel. The Heater requires three (3) double pole 40amp breakers. The decision I am trying to make here is do I install a sub panel next to the heater in the closet and put the three double pole breakers there to feed the heater with short runs of wire or do I just put the breakers in the main panel and feed the three 8awg wire to the heater in the closet. I ha e the space in the main panel for the breakers so that is not an issue. If I install a sub, what size wire is it...2/0? What size breaker would I need to feed that sub. I know it's not a total addition thing just adding up breaker size, but what is the calculation to find out what's NEC and safe more importantly. And for a space issue if the space occupied by three 8/2 wires coming out of the main panel larger than the one wire needed to feed a sub panel?
As for the distance. I would think the wire run from the main panel to either the heater or sub panel would be no farther than say 30ft. Down into crawl or up into attic, over 9ft or so and back into the closet for the heater.
