Electric Hot Water Heaters
   / Electric Hot Water Heaters #1
RichZ
Veteran Member
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
My old electric hot water heater seems to be dying. I'm going to go check out what Home Depot and Lowes have next week. Has anyone bought an electric hot water heater lately? Anyone have any recomendations? I can only use an electric hot water heater in my house. We don't have gas, and I really don't want to get a tank for gas, so we need another electric hot water heater.
Thanks!!
   / Electric Hot Water Heaters #2
By dying do you mean leaking??? If not, thermostats & elements are an easy fix. MikeD74T
   / Electric Hot Water Heaters #3
Have you flushed it to get all the sediment out? Might be worth a try. Might drain it and check your heating elements too; they should be replaceable.
Amazing even on city water how much sediment you can get.
   / Electric Hot Water Heaters #4
We have an AO Smith now. Previously, we had one sold by our electric co-op (sold at $1/gallon capacity) and before that, one from Sears what was in the house when we bought it.
   / Electric Hot Water Heaters #5
Rich- ditto the comments about flushing-- electric elements run so hot they'll force minerals out of solution... this will gather at the bottom, gradually building up to "smother" the lower element, blocking heat transfer--or worse. Not that we live in hard water areas or anything!:cool:
   / Electric Hot Water Heaters #6
Rich,, I just bought a new one a few months ago. We had a 80 gal. When the kids were growing up so we decided to go to a 50 gal. The only reason we replaced it was we were having a new well pump and xtrol tank put in and I wanted the whole thing relocated to the center of the house.. Sooo I told them to replace the 努ater heater at the same time,, the old one was 35 years old too.. The price was about the same as the Big Box stores.
One problem I had with the new one was the T-stats settings.. At first I didn't notice but when I got my first electric bill Wow... It took another month to get them adjusted right.. The top element was doing all the work and it cost me !!!
   / Electric Hot Water Heaters #7
I agree , just what is dying ?It could be a simple fix. (element).Fingers crossed.
But we need to know How Old It is? Leaking, not heating? two elements to it? overheating?
All this will help all of us to help you.
   / Electric Hot Water Heaters #8
I bought a Westinghouse at Lowes about 2 years ago. It's holding up well.
My schpeal on electric HW heaters is to keep them well grounded, use dielectric nipples at the connections, absolutely flush it once a year (make sure you turn it off before you flush).
   / Electric Hot Water Heaters #9
Just a little bit of advice - i always replace the crappy cheap gate drain valves with a good ball valve style. This allows much better flushing (which i would do more often than once a year) and you do not need to worry about a piece of junk getting caught in the valve preventing it from shutting off completely.
Ken
   / Electric Hot Water Heaters #10
I've had bad luck with a "high end" 80 gallon unit sold by Whirlpool and made in Tennessee by a major water heater manufacturer. Bought it at a box store. Two problems: The temperature control is a cheap potentiometer (it's a Ceramet ceramic pot for the geeks in the crowd). A lot of these pots get flakey after about 50 adjustments and don't like high humidity. The relays are undersized, and have stuck on. An online check shows this to be a common problem. There are also failures to an open. We have two of them (on one each geothermal heat pump) and the one that is cycled the most is giving trouble. Some day I'll just re-do the controller board for it.
In the old house, we had the standard hot water heater where you could replace the thermostat by the elements with a generic thermostat you could get at a hardware store. We were on well water, and all the comments on flushing are correct. The ball valve idea is great! Seems like very 3-4 years it needed a new thermostat.
So at this point, the old bimetallic thermostat looks better than the electronic control, just because the silly engineers that did the electronics control don't know enough about selecting the correct components (or their management knows too much about selecting parts that will barely make it past the warranty period).
With the geothermal heat pumps that also make hot water, the water is circulated through the heater via the drain valve in the bottom (and the hot water out at the top). In theory, this means that "the pot is always stirred" and sediment isn't a problem. In practice, well, time will tell. Surely someone in the construction trade wouldn't steer me wrong!
So I'd stay with the old fashion thermostat. Buy whatever has the most insulation around the tank. Replace the drain valve with a ball valve. Flush out the sediment annually.
Question for keegs: With regard to "well grounded", do you consider the ground provided by the AC power connection to be OK? And do your grounding concerns change if you have plastic/PEX vs. copper pipes?
Pete
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2009 MACK CXU613 DAYCAB (INOPERABLE) (A50854)
2009 MACK CXU613...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
