Electric fencing ..
   / Electric fencing .. #1
jnixon
Spruce Grove, Alberta.
Kubotas, L2800, B6200, RTV900..
Quick question for anyone with electric fencing experience, is it normal for the energizer's to constantly 'click' while powered on? Or are they only supposed to click when the fence is touched? We have all wooden fencing at our facility but we have an energizer here that I was considering using for a temporary pen and was wondering if that's normal behaviour..
   / Electric fencing .. #4
If you listen to the clicks and time it perfect, you can touch the wire between the clicks without getting shocked. :D If you get shocked, your timing is off.:eek:
   / Electric fencing .. #5
It's maybe just because we live in Florida but we had a large section of chain-link fence hooked up to a fence charger and lightning hit our fence, traveled through ground and did over $7,000 damage and our insurance co. dropped us like a hot potato.
Be careful of electric fences and the charger was NOT plugged in..
   / Electric fencing .. #6
Mine clicks once the power is turned on.
One thing I've learned is that a simple inexpensive electric fence tester (about $10) is worth it's weight in gold if you have a problem with the fence and trying to locate it.
   / Electric fencing .. #7
We have a Zareba, they call it an "Electric Fence Controller" and yes, it clicks. The User's Manual says it is supposed to click 40 to 60 times per minute. This tells you there is enough voltage to deliver a shock.
We are containing goats and need a lot of voltage. Our system puts out 10K volts.
While working on the fence the other day, I learned that the handles on my pliers were not well insulated. I was squatting down beside the fence and the jolt set me on my backside. Now I know why my big buck stays well back from the fence.
   / Electric fencing .. #8
The Click is NORMAL. If it ain't clicking, it ain't working right.
   / Electric fencing .. #9
On our charger, Zarba, it clicks when it sends a shock out. Our unit also has a yellow light that flashes @ the same time the click sound is heard. If the light is dim I know I have a grounding out problem & go around looking for something, usually tall weeds, on the hot wire.
I'd second the recommendation to get a tester. They are cheap & a good way to track down sections where a short exists.
2014 Nissan NV200 Cargo Van (A55788)
2014 Nissan NV200...
2015 Mitsubishi Outlander Sport SUV (A55758)
2015 Mitsubishi...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
