Electric car -- A different thought
Status
Not open for further replies.
   / Electric car -- A different thought #1
coffeeman
Platinum Member
Hi all.
I read with interest all of the posters. They all seemed right to me.
I also seen something, on the news, about a ray gun or lazer gun that's being expermented with. Some kind of heat thing causes the shootee to be burned with heat but causes only pain and no damage. It's like something from scifi.
Thus, this energy thing. We all think traditional. Make a better gas car or electric car. How about cooking oil? I think someone will come up with something out of left field. Something so simple we will be saying, "Why has no one ever thought of that before?
I'm sure many are thinking "out of the box". It's a matter of time.
Cheers...Coffeeman
   / Electric car -- A different thought #2
Well, as with many great inventions, the technology already exists. All that is needed is a market for it, or a need (necessity) for it, and someone to realize how to package it properly. Consider the iPod. There was not a single new peice of technology in the original iPods. It was all just a matter of reading the market and knowing how to make the technology friendly and appealing. All of that will be needed for progress in the electric car market. Ten bucks a gallon for gas will push things along too.
   / Electric car -- A different thought #3
You guys are so correct. The electronic drive technology in any modern forklift is light years ahead of the automotive industry. From Electronic steering to wire guidance, someone in the auto ind. can take existing technology and assemble a real decent commuter car. Mass production would drive the cost down. Battery charging could take place at off-peak hours when you could obtain a reduced rate from the utilities. Ahh, the possibilities.
   / Electric car -- A different thought #4
Electric fork lifts can run for long periods of time, but not at high speed. And their battery packs weigh, litterally, tons. Now take that forklift battery and motor and take a look at the electric drag racers. They can spin it up to run sub 10 second 1/4 miles at 150+ MPH, but can only get a couple runs before draining the battery. The sweet spot for highway speeds and maximum run times has only recently passed the 100 mile range before recharging. For a one car family, that is not acceptable because if you want to go on a trip, you cannot. For a two car family it might make sense to have one car that is vacation/long trip capable and the 2nd being a short range electric.
I have one car, an Impala, that gets driven 15 miles a day, 5 days a week.
Our second vehicle is a truck or van that gets driven 15 miles once a week.
However, both need to be capable of going on multi-hundred mile trips, depending on if we want to go out of town with good gas mileage(the car) or need to transport the entire extended family or tow the tractor on a trailer.
An electric vehicle with a range of under 500 miles would not be practicle to replace either of our current vehicles. :(
   / Electric car -- A different thought #5
Yes, but an electric with that 100 mile range, might be extended to several hunderd miles, or indefinitely, with the addition of a small efficient diesel generator. In fact, give up half that range in batteries to accomidate the generator and maintain weight. The most efficient output of this generator would be just slightly larger than the vehicles demand while cruising at highway speed on a level road. It would run at this output when commanded, with it's slight surplus recharging the batteries. This would allow you to run in that efficient diesel electric cruise mode with the battery pack providing that additional demand current for acceleration and extended hill climbs.
Automobile engines and cars in general are most efficient while cruising at steady state highway speeds(ref EPA city/highway mileage figures). But they are actually terribly inefficient because the engine is oversized for this aplication, as it needs to be large enough to accelerate the vehicle adequately and climb hills/tow loads. So at highway speed, they have all these excess moving parts(additional cylinders ect) consuming energy and burning fuel, when only a fraction of their output capacity is required for this average task. That is one reason why a geo metro gets 50 MPG. It's most efficient engine output is nearer to the demand at highway speed. Because of this it is underpowered in acceleration and hillclimbs. It is for this same reason that Semi's are pretty efficient in weight moved to fuel consumed. Again, they are not spectacular in acceleration and on hills.
I would guess that they could make a car today that gets 100 MPG at 55 MPH down the highway, but it wouldn't climb hills very well, and it would, like the locomotive, take a very long time to get to speed. Before the solar races they have nowdays, universities used to build vehicles to compete in such trials. Longest distance traveled at a given speed, on a given ammount of fuel.
Something interesting I came across last year while surfing, was a gentelman in, I believe oregon who took a VW Rabbit and converted it to electric. It was OK for local trips, but range was an issue. So he found a Rabbit Diesel and cropped just the front end drivetrain off of it and made it into a trailer that he tows behind the electric Rabbit. He has remote control cables back to the trailer, and out on the highway he starts the diesel and engages it to provide thrust at highway speed. He can either completely disengage the electric motor, or by leaving it engaged, he can use regenerative braking to trickle charge the batteries in the electric rabbit. This of course cuts down on his diesel cruise mileage, but the batteries in the rabbit are fully charged when he reaches his destination:)
There are a couple of ways to skin this cat, but no one has put the whole package together. Again, beter batteries would make this much easier...
   / Electric car -- A different thought #6
They've already done that with the plug in Prius, haven't they? Gas, not diesel, but same idea. Charge the batteries on house current. It runs on batteriesc until you drain the batteries, then switches to the gas engine to drive and charge.
Indefinitely is, however, a long time. ;)
   / Electric car -- A different thought #7
The Prius is slightly different, the gas engine both charges the battery and provides direct drive to the wheels. I think the upcoming Chevy Volt is closer, it seems like the gas engine is just a generator (but it's only a subtle difference).
Out of curiosity, how many of you believe in electric cars enough to dump your oil furnace for an electric heater? In theory the electric will be cheaper when fuel prices reach a certain level, and that crossover point should be much lower than for cars since you don't have to worry about battery technologies. And if you'd prefer natural gas/propane for heating maybe we should look into that for cars instead of electric?
   / Electric car -- A different thought #8
I guess I was thinking indefinitely as long as the fuel tank was full:).
I think the idea behind the plug-in prius was less gas burnt. There are some who are making conversion charger kits for existing prius vehicles. I think they were saying local commute mileages could be increased to as high as 80MPG by starting your morning commute with a fully charged battery. On longer trips the vehicle drops back to it's base cruise fuel economy. You are of course substituting electrons for gasoline, but I would rather buy electricity(produced domestically) than gasoline made from foreign oil. Now I wonder what kind of mileage you would get doing that to a diesel powered prius that already gets around 70 MPG?
   / Electric car -- A different thought #9
RonMar said:
... but I would rather buy electricity(produced domestically) than gasoline made from foreign oil.
Aren't there oil and NG fired power plants?
   / Electric car -- A different thought #10
There will be have to be some major infrastructure upgrades if a plug in model electric car ever became popular. Where would all the juice come from? Peak or off peak it is still more demand. When is the last time you heard of a new Nuclear power plant? New coal powered plants are being fought tooth and nail. Wind farms, basically the same "not in my backyard story". Natural gas fired is the only other logical choice and the amount of flak they are catching over water use, pipelines and transmission lines is amazing.
Just a thought.
Status
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
STAR EV 36V...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
