Electric Brake Adjustment
   / Electric Brake Adjustment #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
I'm rewiring a newly purchased used dual-axle trailer with brakes on all four wheels and I trying to determine how a single line vehicle control wire (the blue-one) controls multiple brakes. It would seem any difference in wire impedance or the brake shoes being out of adjustment would result in significant braking performance at each wheel. Will the normal brake auto-adjusting mechanism compensate for the electrical differences between the controller and each individual wheel or is there an accepted procedure? As usual, I should think less and do more but as the scorpion said "it's my nature." TIA
   / Electric Brake Adjustment #2
Unless you have some serious connection problems, the minute small differences won't be noticed.
Trailer brakes are not that precise anyway, I wouldn't expect Porsche type performance from them.
   / Electric Brake Adjustment #3
There are differences. You just have to live with it. None I have ever seen are auto adjusting. You need to adjust them at 1,000 miles then about every 3,000 or so manually.
Chris
   / Electric Brake Adjustment #4
I have a one year old Ringo dump trailer with a similar problem. The left front locks up before the others start to do anything at all. Maybe someone could give a quick walk through of how to adjust electric brakes. I looked around here for a while but couldn't find anything.
   / Electric Brake Adjustment #6
As far as the adjustment goes, this article describes how it is done and following these instructions will get all wheels adjusted the same. Now that might fix the problem of one locking up ahead of the others, but when one locks up ahead of the others, I'd be pulling the drums off to have a look. Has a grease seal leaked grease on the brakes, in which case, new brake shoes are needed. Or has a broken or shorted wire caused the other wheels to not be working? If one wheel works differently from the others, how did one get adjusted differently from the others? In other words, I'd sure suspect the problem to be something other than adjustment.
   / Electric Brake Adjustment #7
In our area a yearly trailer inspection is required. This means the brake drums must be pulled to have a look at the brake shoes and other components. That means the bearings are grease once a year and the brakes get a professional adjustment once a year. It saves on doing it oneself unless you have a high mileage/year trailer.:D
Thanks all, the instructions help. It has been many years since I have needed to adjust drum brakes.
Has anyone heard a logical reason for the ridiculous trailer wire-code standards? Let's see; green is right-turn lights unless it is the marker lights in which case black might be ground unless it is positive which should never be connected to the white because it could short circuit the red wiring in your vehicle. :eek:
   / Electric Brake Adjustment #9
You really don't have to follow that or any other color code. As long as your connectors have the correct functions wired to the appropriate pins, you are good to go.
   / Electric Brake Adjustment #10
Believe it or not this same color code goes all the way into semi trailer wiring. Only diff is blue is aux.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2012 Honda Accord Sedan (A51694)
2012 Honda Accord...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
