electric actuator for skid steer attachment release
   / electric actuator for skid steer attachment release #1
RoyKing
Platinum Member
Gainesville Florida
M7060HSC/18, RTV-X1100C
To make getting off the tractor unnecessary to change implements. Does somebody sell this?
   / electric actuator for skid steer attachment release #2
It would be a great application, yet I have never seen one.
I have a hyd coupler which is GREAT, but still often need to deal with hoses and electrical connections.
   / electric actuator for skid steer attachment release #3
Some OEMs use them I hear. I had decent results when I made my power SSQA with one. https://www.tractorbynet.com/forums/customization/321704-linear-actuator-power-ssqa.html
I have most of the parts to build a new one for my new machine. It will be hydraulic this time. I have a 3rd function already plumbed in up there now, so there will be minimal extra cost for hydraulics. Hydraulics will be a bit more durable & faster. But I wouldnt recomend against a linear actuator to anybody. I might have used one again if I didnt have the 3rd function.
The latches on the back are going to be unique to each OEM, unlike the front which conforms to the SSQA standard. So either you need to use the OEM solution or build your own. You might be able to get lucky or modify a different OEM one to fit your machine. The cylinder alone for a Kubota power SSQA is over $800. I got a small cylinder with the proper stroke for $50.
Turns out Kubota makes a hydraulic cylinder with a complete separate circuit, expensive. If you have 3rd function I'd like to hook to it, so I asked fite rite hydraulics to come up with kit with hoses and pins.
   / electric actuator for skid steer attachment release #5
As I noted above, it was over $800 for just the cylinder when I looked. Couple hundred for other brackets, guards & stuff. That didnt even include the control valves. It's an option on the Grand Ls, although I'd guess it might fit on the economy Ls & probably others as well.
Curious to hear if FitRite comes up with a cylinder & brackets before I get around to fabbing something up. Might be worth it, I'm happy with his TnT on my previous & current machine.
Brian from fite right hydraulics estimates $250-300 with hoses and brackets, he will get back to me soon. I keep updating
PALLET OF 3 DEF TANKS (A45046)
PALLET OF 3 DEF...
24in Tractor Backhoe Bucket BT4555 (A44789)
24in Tractor...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A43003)
2017 MACK CHU613...
Frontier 8' Rake (A44501)
Frontier 8' Rake...
10’ WROUGHT IRON FENCE (A45046)
10’ WROUGHT IRON...
2017 Rotair Sand Blaster and Trailer (A44391)
2017 Rotair Sand...
