elec. pump
   / elec. pump #1
davis1
pleasantville ia
1966 ford 3000
Could I put elec. puel pump on ford 3000 tractor if so what would I half to do. Thank you
   / elec. pump #2
it's not a hard job to rebuild the oe fuel pump up fron ton the gassers, but to answer your question, YES, you CAN install an electric fuel pump.
find the lines to and from the oe fuel pump. one is from tank.. the other is to carb.
patch the pump in with appropriate fuel line, mount it, get power from the run side of the key switch.
if it is an adjustable pump as some ar from 0-7, I would aim for 2-4 psi MAX
   / elec. pump #4
An electric fuel pump can be powered through an oil pressure switch. No oil pressure and she shuts down.
the oil sender on that ford is basic open at 6psi type job.. closed when off.
   / elec. pump
I would like new pump but cant get to back bolt with out taking radiator off right now running it gravity fed runs fine so far thank for your help.
   / elec. pump #6
can't get to back bolt?
   / elec. pump #8
can't get to what? please be more specific? nothing says you have to REMOVE the old pump.. just rehose .. and leave the old pump in place.
   / elec. pump #9
Think he is saying he would like to put OE pump on but can't get to bolt to take old pump off , so is going to by pass with electric pump to keep running for now ??? At least I Think that is what he means , but We all know what Happens when I Think :thumbsup:
Fred H.
   / elec. pump #10
maybee.
either way. he can run electric till he repalces oem.. gravity of the holley didn't work well. gravity on a zenith may work better.. simpler carb...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
24' Free Standing Panel with Swing Gate (A50515)
24' Free Standing...
78" Skidloader Log Grapple (A50774)
78" Skidloader Log...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A52141)
2005 INTERNATIONAL...
