ehydro kickout
   / ehydro kickout #1
smit360
Michigan
John Deere 3120
hey guys have another concern I would like to share and get your expertise on. I have a 3120 with ehydro and when i am pulling real hard in B range sometimes it will kick out of B range into neutral. I haev never pulled real hard in C or A range so I do not know if it will do the same thing. Is this a saftey kickout when i over load the tranny or is this a problem i should haev checked out? Thanks
Jay <font color="green"> </font>
   / ehydro kickout #2
Never have seen this myself. Make sure you are fully in range. At first, it i seems a little tricky going in and out of range. Maybe you aren't quite there!
   / ehydro kickout
maybe this is true, it doesnt happen all the time, the times it has happened have been when i am doing heavy rear blade work or pulling a fully loaded dump trailer up a real steep incline. During these times the lever woudl just pop out of range. <font color="green"> </font>
   / ehydro kickout #4
I have a 4310 ehydro and have worked A and B range hard and have driven for an hour on the highway in C range and have never had them slip out of gear.
Richard
   / ehydro kickout #5
I have had that happen on my 4720, but I think it was my fault. I don't think I had the selector centered.
D.
   / ehydro kickout #6
I think you need to ask your dealer to look into this issue. This is not normal.
   / ehydro kickout #7
I have a 3320 and was mowing and had it pop out of gear once- but I'm pretty sure I hit the gear shift with my elbow. I have some steep hills that I rotary mow and come into a heavy load in loose soil nearing the crest. I'm very careful there- if it pops out of gear on a slope- I'm gonna take a ride I'll never forget backwards down the hill. I'd have it looked at- it could be pretty dangerous depending on where you are and what your towing.
   / ehydro kickout #8
I agree with what has been said. I've had my 4320 do the same thing, but I think it is because I didn't get it completely in proper range. It is an eye opener when it happens on a hill - thus I've taken extra care when changing to a different range, and I haven't had the problem continue since I've been paying closer attention.
   / ehydro kickout #9
I am not sure what really happened as I didn't stop and really check it out...just kept cutting....
I was mowing with the rear grooming mower on my front slope. I had been up and down the hill several times with no problems (note: steep enough that I had to use 4wd near the top of the slope and then used 4wd to slowly crawl down the hill). On one trip, just as I started back down the hill, I was freewheeling so fast all I could do was try to keep from flipping as I tried to apply the brakes, without locking a tire and make it more likely to tip. I put two different sets of skid marks, digging up grass, before I got leveled out and slowed down. I should have stopped, checked everything, and assessed what happened. I didn't. As I was on level then, I pulled it out of 4wd (with my foot, as I usually do), it had definitely been in 4w. I can't really say if I pushed the shift forward to be sure it was in low. I don't think it had slipped out, or that I had knocked it out. But, I really don't know.
One thing I do know is I check it well now and keep my mind on where to steer if it should happen again.
A little freewheeling down a steep slope certainly does add excitement to mowing the lawn! /forums/images/graemlins/shocked.gif
Tom
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
CAT Skid Steer (A50322)
CAT Skid Steer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
2012 Chevrolet Silverado 2500 HD Enclosed High Top Service Truck (A52377)
2012 Chevrolet...
