EGR failure....
/ EGR failure.... #1
spruce Deere
Veteran Member
Northmost Idaho
John Deere 790 with loader, LS xr3140h loader and cab,1150 case dozer
After 6 years and 3 months of near flawless operation, AND out of warranty the XR 3140's egr valve gave it up. Better now while getting ready for the spring get everything done race and not in the middle of the race.
The code S27 F08 made itself known this morning moving some things around with the tractor. So I pulled the tractor in the shop, turned off the key and a screechy, grinding noise eminated from under the hood, and a little later found it's the sound of the failed electrical controlled egr.
I did a little research, read sometimes removing and cleaning it works, but it didn't this time.
Plus side of all this malarkey, I found the obd port behind the bottom kick panel on the drive pedal 'right' side of the dash. Was happy to see it plugged right in to my scan tool. Then learned the dpf is 'severely' plugged.... a symptom of a malfunctioning egr.
Like the tractor, but do not like the pointless emissions forced oppon it, or any brand of any implement at all.
I tell ya, getting the dpf cleaned is nothing 'under 200 clams' compared to the price for a new egr thing $1,300 bucks and some change.
Looks like there is other options though😁
/ EGR failure.... #2
The S27 F08 code is EGR position fault. Either the valve is stuck or the position sensor has failed. It doesn't automatically mean your DPF is plugged. S81 F07 means it's plugged, and S81 F0 means DPF overload and needs a regen. S81 F11 means DPF fault triggers reduced torque (Engine derate) which can be caused by any of the above faults. If you try to fix it the right way and replace the EGR valve, it's gonna get really expensive because the original Erae valve was discontinued by the manufacturer. Nothing LS could do but change to a different Kamtech valve, so it has to have a conversion kit installed to be able to install the new valve. And the ECU software would need to be updated as well. Some people have cleaned the EGR valve with limited success. If it fails electrically, (position sensor or H-bridge circuit), there's nothing you can do but replace it. If the EGR valve and piping is shiny and wet inside, the EGR cooler could be leaking coolant into it. You can take the DPF apart and inspect it for plugging if necessary. Possibly consider deleting the system versus having it converted to the new EGR valve. There are people out there that offer it. Sadly, if it would have failed within 5 years, the emission warranty would have covered the new EGR and conversion kit.
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
John Deere 7200 6R Planter (A66285)
John Deere 7200 6R...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
Club Car (A59231)
Club Car (A59231)
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
