Egg Custard FAIL - please advise?
/ Egg Custard FAIL - please advise? #1
KilroyJC
Elite Member
Appalachia
1962 Case 430, 1995 Craftsman Yard Tractor/mower, 1949 South Bend 9A Lathe, WoodMizer Lx55 sawmill, Kubota KX033-4 Mini-Excavator
Since we got chickens back in May, we have plenty of eggs.
The cost per egg based on expenses is finally below $5/egg.
I decided to make some egg custard, and went with a very basic recipe of 1 gallon milk, one dozen eggs, two cups of sugar, and some vanilla extract.
Cooked it up as per instructions (simmer on stove for 30 minutes) and ladled it into a bunch of five-oz cups, and put them in the fridge overnight.
They did not set.
SO, I cracked another dozen eggs, beat in a 1/4 cup of flour and two tablespoons of cornstarch, emptied all the cups into a pot and added the additional eggs, repeated cooking, and ladled into cups and put them into the fridge overnight.
Woke up this morning and they still didn’t set!
Today, I will pick up some dark rum, strain/funnel the liquid into some bottles and add rum, and make eggnog for the winter, because I am not going to waste a gallon of milk and two dozen eggs.
Any culinary experts have any ideas why the custard never thickened?
Thanks.
/ Egg Custard FAIL - please advise? #2
I'm curious as to the answers you'll get; I've never made custard but one day I'll give it a shot, I just fear I'd be the only one to eat it. 😂
I also posted this on another blog I follow (InstaPundit ) and I got the detailed explanation:
George Turner an hour ago
A custard needs to low boil at least three minutes or the alpha-amylase will turn the starch you added back into sugar, resulting in sweet eggnog. This happens over time, as the starch conversion takes time, especially at fridge temperatures.
Alpha-amylase is the enzyme that breaks down the starches found in barley malt and turns them into fermentable sugars. It basically rips starch molecules into hunks of smaller starches, until it gets to the larger sugars. The enzyme also found in abundance in human mouths, as we ended up with a whole lot of duplicate genes for it, whereas other primates only have a couple. This indicates we've been surviving on starches for a long long time.
Anyway, alpha-amylase achieves a peak activity at about 155F, so a lot of pre-thermometer beer lore is centered around clever ways to hit that temperature for mashing, such as adding X units of boiling water to Y units of wort, in sometimes elaborate sequences, with pretty precise time intervals. There's also a beta-amylase enzyme that breaks down starches by nibbling sugars off the ends, and beta has a slightly different temperature for optimal activity, so by being really precise with the temperatures, the brewer can adjust they type of sugars that come from the grain, and thus residual sweetness, mouth feel, and some other factors that separate a really good European beer from Coors Light.
Anyway, alpha-amylase keeps on working at lower temperatures, which is why your saliva is full of it. To keep it from continuing to convert all the starches in a malt into sugars, which would screw up a lot of great beers, the mashing the temperature is raised to 167 F and held there for a few minutes, which denatures the amylase enzyme. A brief temperature excursion won't denature it all.
And so it is with your custard. Eggs have a lot of amylase enzyme in them, and your added starch is a starch, the very thing amylase enzyme destroys, whether quickly at 155 F or slowly at cooler temperatures. So you have to kill the amylase with a good but low boil that keeps the custard above 167 F for three or more minutes.
If you didn't do that, you can just reboil your custard, and add more starch because the starch you'd added got turned into a variety of sugars.”
so, basically, I need to use a thermometer.
/ Egg Custard FAIL - please advise? #4
Sometimes cooking instructions seem easy, but the details matter. The writer knows what they meant, but often the writer assumes facts not in evidence.
I finally got pretty good at boiled eggs. My wife 'followed' my instructions but ended up with way undercooked eggs. A minute here or there can make a big difference.
Your thermometer should help. In some cases, changes in barometric pressure and humidity can tip the scales on things like that, too. Enjoy the eggnog and the journey.
Every day should be a learning experience 😂🤣
/ Egg Custard FAIL - please advise? #6
While we're on the subject of eggs and the importance of directions and time. I've been doing hard boiled eggs like Mom told me to which was in a pan of boiling water with 1 week old eggs. Still had a problem peeling them and some times the yolk would have a green ring or the very center wasn't cooked. I finally came across a video on how to cook them properly. Turns out you don't want them in the water because the shells are porous and something happens to make the membrane stick to the egg during cooking. What needs to be done is steam them for 15 minutes, then an ice bath for 15 minutes and they come out beautiful and are easy to peel and the egg white remains intact. Just a small change makes all the difference in the world.
/ Egg Custard FAIL - please advise? #7
Or just add a teaspoon of vinegar to the water. Mom always overcooked things. :)
/ Egg Custard FAIL - please advise? #8
We boil eggs in the Instant Pot. The shells fall off.
I always added around a half-cup and some salt, too. I fill the pot halfway with cold water,put the eggs in the pot, and bring to a boil. When it gets to a full boil, it gets turned off, and fifteen minutes later the eggs go into ice water until dead cold.
unless the eggs are too fresh, they are usually easy to peel, and are cooked perfectly.
I would like to try this tip I recently saw for peeling: put 3-5 eggs in a glass Jar with 2 oz water, close the jar, and shake gently for 30 seconds. Apparently, once you get a couple cracks in the shell, the water can work it’s way underneath and help separate the shell and membrane from the whites.
/ Egg Custard FAIL - please advise? #10
In my experience, cracked eggs leak albumin and do not make the best boiled eggs.
The process I describe is for removing the shells after then have been boiled and cooled - I should have made that clearer (editing now)
/ Egg Custard FAIL - please advise? #12
They did not set.
Thanks.
Post your recipe?
FWIW, I would "test" with a smaller amount; scale recipe to 4 eggs accordingly, and experiment. Dial the recipe in, and then scale up.
Have you considered a baked custard?
/ Egg Custard FAIL - please advise? #13
That might be your problem right there. It's often better to use your eyes and the touch and feel to determine if it is properly cooked
Your profile says Appalachia What is your altitude? Altitude matters when making custards because water boils at a lower temperature so you gotta cook longer.
Post your recipe?
I love flan, but I wanted to try a stovetop custard. Right now, I a, glassing more eggs for storage, but I will try again in a couple weeks when it gets cooler.
2134 ft. According to GoogleEarth. Not ridiculously high.
/ Egg Custard FAIL - please advise? #18
They did not set.
Thanks.
Been making custard from extra eggs for 40 years. Never boiled it, always baked it for 1.5 hours at 350 degrees. Always came out great.
/ Egg Custard FAIL - please advise? #19
Every custard I ever made was thickening by the time I took it off heat. An instant read thermometer is almost required.
Cook's Illustrated has a simple guide...
"Egg-based puddings and custards can curdle if cooked beyond 185 degrees. We take crème anglaise off the heat when the mixture registers 175 to 180, but when making the base for ice cream we push the temperature to 180 to 185 for maximum thickness. Baked custards, such as flan and crème brûlée, should jiggle (but not slosh) when gently shaken. This will occur between 170 to 175 degrees."
2012 CATERPILLAR 316EL EXCAVATOR (A62129)
2012 CATERPILLAR...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
